Datasheet Linear Technology LTC3882IUJ-1#TRPBF — Даташит
| Серия | LTC3882-1 |
| Модель | LTC3882IUJ-1#TRPBF |
Dual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management
LTC3882-1 - Dual Output PolyPhase Step-Down DC/DC Voltage Mode Controller with Digital Power System Management
PDF, 1.2 Мб, Файл закачен: 24 сен 2017
Купить LTC3882IUJ-1#TRPBF на РадиоЛоцман.Цены — от 270 до 677 ₽9 предложений от 9 поставщиков IC REG CTRLR BUCK PMBUS 40QFN. Buck Regulator Positive Output Step-Down I²C, PMBus DC-DC Controller IC 40-QFN (6x6). PMIC - Voltage... | |||
| LTC3882IUJ-1#TRPBF Analog Devices | 359 ₽ | ||
| LTC3882IUJ-1#TRPBF Linear Technology | 617 ₽ | ||
| LTC3882IUJ-1#TRPBF Analog Devices | 629 ₽ | ||
| LTC3882IUJ-1#TRPBF | 677 ₽ | ||
| Корпус | 6x6 QFN-40 |
| Код корпуса | UJ |
| Индекс корпуса | 05-08-1728 |
| ADC | 16-Bit |
| DAC | 12-Bit |
| Demo Boards | DC2252A-B,DC2312A-A,DC2312A-B |
| Design Tools | LTspice Model,LTpowerCAD Model |
| Экспортный контроль | нет |
| Основные особенности | Burst Mode, Differential Remote Sense, PolyPhase, PMBus, I2C Control, EEPROM, ADC, DCR Current Sense, Sequencing, Margining, Tracking, External Synchronization |
| Function | DC/DC Regulator With Power System Management |
| I/O | PMBus/SMBus/I2C |
| Isupply | 32 мА |
| Monitors | Vin, Iin, Vout, Iout, Temperature and Faults |
| Количество выходов | 2 |
| Диапазон напряжения питания | 3V to 13.2V |
| Vin Max | 13.2 В |
| Vin Min | 3 В |
- Accurate Temperature Sensing with an External P-N Junction &mdash AN137PDF, 540 Кб, Файл опубликован: 20 сен 2012
Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.Выписка из документа - Overview of the EEPROM in LTC PSM Devices &mdash AN145PDF, 3.0 Мб, Файл опубликован: 10 май 2014Выписка из документа
- Power System Management Addressing &mdash AN152PDF, 169 Кб, Файл опубликован: 12 июл 2016Выписка из документа
- Linduino for Power System Management &mdash AN153PDF, 1.3 Мб, Файл опубликован: 24 фев 2016Выписка из документа
- Fault Log Decoding with Linduino PSM &mdash AN155PDF, 230 Кб, Файл опубликован: 26 янв 2017Выписка из документа
- In Flight Update with Linduino &mdash AN166PDF, 1.1 Мб, Файл опубликован: 10 апр 2017Выписка из документа
Серия: LTC3882-1 (4)
- LTC3882EUJ-1#PBF LTC3882EUJ-1#TRPBF LTC3882IUJ-1#PBF LTC3882IUJ-1#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | External Power Switch Buck Controllers
- Power Management > Switching Regulator > Digitally Programmable Regulators
- Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3882IUJ-1TRPBF, LTC3882IUJ-1 TRPBF, LTC3882IUJ1#TRPBF, LTC3882IUJ 1#TRPBF
