Datasheet Linear Technology LTC3884ERHE-1#TRPBF — Даташит
| Серия | LTC3884 |
| Модель | LTC3884ERHE-1#TRPBF |
Dual Output PolyPhase Step-Down Controller with Sub-Milliohm DCR Sensing and Digital Power System Management
LTC3884: Dual Output PolyPhase Step-Down Controller with Sub-Milliohm DCR Sensing and Digital Power System Management Data Sheet
PDF, 4.1 Мб, Файл закачен: 27 мар 2018
8 предложений от 8 поставщиков IC REG CTRLR BUCK PMBUS 48QFN. Buck Regulator Positive Output Step-Down I²C, PMBus DC-DC Controller IC 48-GQFN (5x6). PMIC - Voltage... | |||
| LTC3884ERHE-1#TRPBF Analog Devices | 641 ₽ | ||
| LTC3884ERHE-1#TRPBF Analog Devices | 739 ₽ | ||
| LTC3884ERHE-1#TRPBF Analog Devices | по запросу | ||
| Корпус | 5x6 GQFN-48 |
| Код корпуса | RHE |
| Индекс корпуса | 05-08-1527 |
| ADC | 16-bit |
| DAC | 12-bit |
| Demo Boards | DC2165A,DC2283A,DC2084A,DC2298A,DC2605A |
| Design Tools | LTspice Model,LTpowerCAD File |
| Экспортный контроль | нет |
| Основные особенности | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization |
| Function | DC/DC Regulator With Power System Management |
| I/O | PMBus/SMBus/I2C |
| Isupply | 23 мА |
| Monitors | Vin, Iin, Vout, Iout, Temperature and Faults |
| Количество выходов | 2 |
| Рабочий диапазон температур | от 0 до 85 °C |
| Диапазон напряжения питания | 4.5V to 38V |
| Vin Max | 38 В |
| Vin Min | 4.5 В |
- Accurate Temperature Sensing with an External P-N Junction &mdash AN137PDF, 540 Кб, Файл опубликован: 20 сен 2012
Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.Выписка из документа - Overview of the EEPROM in LTC PSM Devices &mdash AN145PDF, 3.0 Мб, Файл опубликован: 10 май 2014Выписка из документа
- Power System Management Addressing &mdash AN152PDF, 169 Кб, Файл опубликован: 12 июл 2016Выписка из документа
- Linduino for Power System Management &mdash AN153PDF, 1.3 Мб, Файл опубликован: 24 фев 2016Выписка из документа
- Fault Log Decoding with Linduino PSM &mdash AN155PDF, 230 Кб, Файл опубликован: 26 янв 2017Выписка из документа
- In Flight Update with Linduino &mdash AN166PDF, 1.1 Мб, Файл опубликован: 10 апр 2017Выписка из документа
- Honing the Adjustable Compensation Feature of Power System Management Controllers &mdash AN170PDF, 8.1 Мб, Файл опубликован: 8 фев 2018Выписка из документа
Серия: LTC3884 (12)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | High Input Voltage Buck | External Power Switch Buck Controllers
- Power Management > Switching Regulator > Digitally Programmable Regulators
- Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3884ERHE-1TRPBF, LTC3884ERHE-1 TRPBF, LTC3884ERHE1#TRPBF, LTC3884ERHE 1#TRPBF
