Datasheet Linear Technology LTC3884IRHE-1#TRPBF — Даташит
СерияLTC3884
МодельLTC3884IRHE-1#TRPBF
Dual Output PolyPhase Step-Down Controller with Sub-Milliohm DCR Sensing and Digital Power System Management
LTC3884: Dual Output PolyPhase Step-Down Controller with Sub-Milliohm DCR Sensing and Digital Power System Management Data Sheet
PDF, 4.1 Мб, Файл закачен: 27 мар 2018
, LTC3884 - Dual Output PolyPhase Step-Down Controller with Sub-Milliohm DCR Sensing and Digital Power System Management; Package: QFN; Pins: 48;...
LTC3884IRHE-1#TRPBF
273 ₽
LTC3884IRHE-1#TRPBF
628 ₽
Рутоника
LTC3884IRHE-1#TRPBF
700 ₽
LTC3884IRHE-1#TRPBF
Корпус5x6 GQFN-48
Код корпусаRHE
Индекс корпуса05-08-1527
ADC16-bit
DAC12-bit
Demo BoardsDC2165A,DC2283A,DC2084A,DC2298A,DC2605A
Design ToolsLTspice Model,LTpowerCAD File
Экспортный контрольнет
Основные особенностиPMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization
FunctionDC/DC Regulator With Power System Management
I/OPMBus/SMBus/I2C
Isupply23 мА
MonitorsVin, Iin, Vout, Iout, Temperature and Faults
Количество выходов2
Диапазон напряжения питания4.5V to 38V
Vin Max38 В
Vin Min4.5 В
  • Accurate Temperature Sensing with an External P-N Junction &mdash AN137
    PDF, 540 Кб, Файл опубликован: 20 сен 2012
    Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.
  • Overview of the EEPROM in LTC PSM Devices &mdash AN145
    PDF, 3.0 Мб, Файл опубликован: 10 май 2014
  • Power System Management Addressing &mdash AN152
    PDF, 169 Кб, Файл опубликован: 12 июл 2016
  • Linduino for Power System Management &mdash AN153
    PDF, 1.3 Мб, Файл опубликован: 24 фев 2016
  • Fault Log Decoding with Linduino PSM &mdash AN155
    PDF, 230 Кб, Файл опубликован: 26 янв 2017
  • In Flight Update with Linduino &mdash AN166
    PDF, 1.1 Мб, Файл опубликован: 10 апр 2017
  • Honing the Adjustable Compensation Feature of Power System Management Controllers &mdash AN170
    PDF, 8.1 Мб, Файл опубликован: 8 фев 2018
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | High Input Voltage Buck | External Power Switch Buck Controllers
  • Power Management > Switching Regulator > Digitally Programmable Regulators
  • Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3884IRHE-1TRPBF, LTC3884IRHE-1 TRPBF, LTC3884IRHE1#TRPBF, LTC3884IRHE 1#TRPBF
На английском языке: Datasheet Linear Technology LTC3884IRHE-1#TRPBF
