Datasheet Linear Technology LTC3886IUKG#TRPBF — Даташит
СерияLTC3886
МодельLTC3886IUKG#TRPBF
60V Dual Output Step-Down Controller with Digital Power System Management
LTC3886: 60V Dual Output Step-Down Controller with Digital Power System Management Data Sheet
PDF, 1.6 Мб, Файл закачен: 24 сен 2017
15 предложений от 11 поставщиков
60V 2X OUT BUCK CNTR W/ DIG PWR. Buck Regulator Positive Output Step-Down I²C, PMBus DC-DC Controller IC 52-QFN (7x8). PMIC...
LTC3886IUKG#TRPBF
550 ₽
LTC3886IUKG#TRPBF
754 ₽
Эиком
LTC3886IUKG-1#TRPBF
от 1 965 ₽
727GS
LTC3886IUKG-1#TRPBF
Корпус7x8 QFN-52
Код корпусаUKG
Индекс корпуса05-08-1947
ADC16-Bit
DAC12-Bit
Demo BoardsDC2155A-A,DC2277A,DC2155A-B,DC2578A
Design ToolsLTspice File,LTpowerCAD File,Linduino File
Экспортный контрольнет
Основные особенностиPMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization
FunctionDC/DC Regulator With Power System Management
I/OPMBus/SMBus/I2C
Isupply26 мА
MonitorsVin, Iin, Vout, Iout, Temperature and Faults
Количество выходов2
Диапазон напряжения питания4.5V to 60V
Vin Max60 В
Vin Min4.5 В
  • Accurate Temperature Sensing with an External P-N Junction &mdash AN137
    PDF, 540 Кб, Файл опубликован: 20 сен 2012
    Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.
  • Overview of the EEPROM in LTC PSM Devices &mdash AN145
    PDF, 3.0 Мб, Файл опубликован: 10 май 2014
  • Power System Management Addressing &mdash AN152
    PDF, 169 Кб, Файл опубликован: 12 июл 2016
  • Linduino for Power System Management &mdash AN153
    PDF, 1.3 Мб, Файл опубликован: 24 фев 2016
  • Fault Log Decoding with Linduino PSM &mdash AN155
    PDF, 230 Кб, Файл опубликован: 26 янв 2017
  • In Flight Update with Linduino &mdash AN166
    PDF, 1.1 Мб, Файл опубликован: 10 апр 2017
  • Implementing Fast Telemetry with Power System Management Controllers &mdash AN168
    PDF, 165 Кб, Файл опубликован: 8 фев 2018
  • Honing the Adjustable Compensation Feature of Power System Management Controllers &mdash AN170
    PDF, 8.1 Мб, Файл опубликован: 8 фев 2018
Статьи
  • The Evolution of High Voltage Digital Power System Management &mdash LT Journal
    PDF, 1.2 Мб, Файл опубликован: 8 фев 2016
Серия: LTC3886 (4)
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | High Input Voltage Buck | External Power Switch Buck Controllers
  • Power Management > Switching Regulator > Digitally Programmable Regulators
  • Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3886IUKGTRPBF, LTC3886IUKG TRPBF
На английском языке: Datasheet Linear Technology LTC3886IUKG#TRPBF
Публикации по теме
