Datasheet Linear Technology LTC3887IUJ#PBF — Даташит
СерияLTC3887
МодельLTC3887IUJ#PBF
Dual Output PolyPhase Step-Down DC/DC Controller with Digital Power System Management
LTC3887: Dual Output PolyPhase Step-Down DC/DC Controller with Digital Power System Management Data Sheet
PDF, 1.2 Мб, Файл закачен: 24 сен 2017
23 предложений от 14 поставщиков
IC REG CTRLR BUCK PMBUS 40QFN. Buck Regulator Positive Output Step-Down I²C, PMBus DC-DC Controller IC 40-QFN (6x6). PMIC - Voltage...
LTC3887IUJ-2#PBF
335 ₽
Рутоника
LTC3887IUJ-1#TRPBF
635 ₽
LTC3887IUJ#TRPBF
675 ₽
LTC3887IUJ-2#TRPBF
Корпус6x6 QFN-40
Код корпусаUJ
Индекс корпуса05-08-1728
ADC16-Bit
DAC12-Bit
Demo BoardsDC1709A,DC2263A-A,DC2263A-B,DC2454A,DC2394A,DC2578A
Design ToolsLTpowerPlay ,LTspice File,LTpowerCAD File,Linduino File
Экспортный контрольнет
Основные особенностиPMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization
FunctionDC/DC Regulator With Power System Management
I/OPMBus/SMBus/I2C
Isupply20 мА
MonitorsVin, Iin, Vout, Iout, Temperature and Faults
Количество выходов2
Диапазон напряжения питания4.5V to 24V
Vin Max24 В
Vin Min4.5 В
LTC3887-1 LTC3887
LTC3887-1
  • Accurate Temperature Sensing with an External P-N Junction &mdash AN137
    PDF, 540 Кб, Файл опубликован: 20 сен 2012
    Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.
  • Overview of the EEPROM in LTC PSM Devices &mdash AN145
    PDF, 3.0 Мб, Файл опубликован: 10 май 2014
  • Power System Management Addressing &mdash AN152
    PDF, 169 Кб, Файл опубликован: 12 июл 2016
  • Linduino for Power System Management &mdash AN153
    PDF, 1.3 Мб, Файл опубликован: 24 фев 2016
  • Fault Log Decoding with Linduino PSM &mdash AN155
    PDF, 230 Кб, Файл опубликован: 26 янв 2017
  • In Flight Update with Linduino &mdash AN166
    PDF, 1.1 Мб, Файл опубликован: 10 апр 2017
  • Implementing Fast Telemetry with Power System Management Controllers &mdash AN168
    PDF, 165 Кб, Файл опубликован: 8 фев 2018
  • Power Management > Switching Regulator > Digitally Programmable Regulators
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers | Multiple Output Buck
  • Monitor, Control and Protection > Digital Power System Management > DC/DC Regulator With Power System Management
LTC3887IUJPBF, LTC3887IUJ PBF
На английском языке: Datasheet Linear Technology LTC3887IUJ#PBF
