Datasheet Linear Technology LTM4650IY — Даташит
| Серия | LTM4650 |
| Модель | LTM4650IY |
Dual 25A or Single 50A DC/DC µModule Regulator
LTM4650: Dual 25A or Single 50A DC/DC µModule Regulator Data Sheet
PDF, 732 Кб, Файл закачен: 25 сен 2017
Купить LTM4650IY на РадиоЛоцман.Цены — от 2 203 до 15 031 ₽20 предложений от 13 поставщиков DC DC CNVRTR 0.6-1.8V 0.6-1.8V. Non-Isolated PoL Module DC DC Converter 2 Output 0.6 ~ 1.8V 0.6 ~ 1.8V 25A, 25A... | |||
| LTM4650IY#PBF Analog Devices | 3 445 ₽ | ||
| LTM4650IY#PBF | 6 385 ₽ | ||
| LTM4650IY-1B Analog Devices | 14 796 ₽ | ||
| LTM4650IY#PBF Analog Devices | по запросу | ||
| Корпус | 16mm x 16mm x 5.01mm BGA |
| Код корпуса | BGA |
| Индекс корпуса | 05-08-1969 |
| Архитектура | Constant Frequency Current Mode |
| Demo Boards | DC2378A-A,DC2481A-B,DC2481A-A,DC2479A-A |
| Design Tools | LTspice File,LTpowerCAD File |
| Экспортный контроль | нет |
| Основные особенности | Internal Heat Sink, Differential Remote Sense, PolyPhase, Resistor Set Frequency, External Synchronization, Temperature Monitor, Burst Mode, Power Good |
| Тактовая частота | 500 kHz |
| Frequency Adjust Range | 400kHz - 780kHz |
| Frequency Sync Range | 400kHz - 780kHz |
| Integrated Inductor | да |
| Ishutdown | 50 мкА |
| Isupply | 4 мА |
| Max Phases | 2, 4, 6, 8, 10, 12 |
| Monolithic | да |
| Количество выходов | 2 |
| Выходной ток | 25 A |
| Output Current 2 | 25 A |
| Switch Current | 25 A |
| Switch Current 2 | 25 A |
| Synchronous | да |
| Topology | Buck |
| Topology 1 | Buck |
| Topology 2 | Buck |
| Vin Max | 15 В |
| Vin Min | 4.5 В |
| Vout Max | 1.8 В |
| Vout Max 2 | 1.8 В |
| Vout Maximum | 1.8V |
| Vout Min | 0.6 В |
| Vout Min 2 | 0.6 В |
| Vref Accuracy Over Temp | 1 % |
| RoHS | Не совместим |
Серия: LTM4650 (3)
- LTM4650EY#PBF LTM4650IY LTM4650IY#PBF
- µModule Solutions > µModule Regulators > µModule Buck Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
