Datasheet Linear Technology LTM4650AIY#PBF — Даташит
| Серия | LTM4650A |
| Модель | LTM4650AIY#PBF |
Dual 25A or Single 50A DC/DC µModule Regulator with 1% DC Accuracy
LTM4650A: Dual 25A or Single 50A DC/DC μModule Regulator with 1% DC Accuracy Data Sheet
PDF, 2.4 Мб, Файл закачен: 27 мар 2018
Купить LTM4650AIY#PBF на РадиоЛоцман.Цены — от 2 265 до 18 072 ₽18 предложений от 12 поставщиков Интегрированные Локализованные к Нагрузке Регулируемые DC - DC Преобразователи | |||
| LTM4650AIY-1#PBF | 6 359 ₽ | ||
| LTM4650AIY#PBF Analog Devices | 7 065 ₽ | ||
| LTM4650AIY#PBF Analog Devices | от 8 231 ₽ | ||
| LTM4650AIY-1 Analog Devices | 16 592 ₽ | ||
| Корпус | 16mm × 16mm × 5.01mm BGA |
| Код корпуса | BGA |
| Индекс корпуса | 05-08-1523 |
| Архитектура | Constant Frequency Current Mode |
| Demo Boards | DC2603A-A |
| Design Tools | LTspice Model,LTpowerCAD File |
| Экспортный контроль | нет |
| Основные особенности | Internal Heat Sink, Differential Remote Sense, PolyPhase, Resistor Set Frequency, External Synchronization, Temperature Monitor, Burst Mode, Power Good |
| Тактовая частота | 500 kHz |
| Frequency Adjust Range | 400kHz - 780kHz |
| Frequency Sync Range | 400kHz - 780kHz |
| Integrated Inductor | да |
| Ishutdown | 35 мкА |
| Isupply | 4.5 мА |
| Max Phases | 2, 4, 6, 8, 10, 12 |
| Monolithic | да |
| Количество выходов | 2 |
| Выходной ток | 25 A |
| Output Current 2 | 25 A |
| Polyphase | да |
| Switch Current | 25 A |
| Switch Current 2 | 25 A |
| Synchronous | да |
| Topology | Buck |
| Topology 1 | Buck |
| Topology 2 | Buck |
| Vin Max | 16 В |
| Vin Min | 4.5 В |
| Vout Max | 5.5 В |
| Vout Max 2 | 5.5 В |
| Vout Maximum | 5.5V |
| Vout Min | 0.6 В |
| Vout Min 2 | 0.6 В |
| Vref Accuracy Over Temp | 1 % |
Серия: LTM4650A (5)
- LTM4650AEV#PBF LTM4650AEY#PBF LTM4650AIV#PBF LTM4650AIY LTM4650AIY#PBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- µModule Solutions > µModule Regulators > µModule Buck Regulators
LTM4650AIYPBF, LTM4650AIY PBF
