Datasheet Linear Technology LTM4677IY#PBF — Даташит
| Серия | LTM4677 |
| Модель | LTM4677IY#PBF |
Dual 18A or Single 36A µModule (Power Module) Regulator with Digital Power System Management
Datasheet LTM4677
PDF, 2.8 Мб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 132
Dual 18A or Single 36A μModule (Power Module) Regulator with Digital Power System Management
|  Купить LTM4677IY#PBF на РадиоЛоцман.Цены — от 1 857 до 14 517 ₽ 17 предложений от 11 поставщиков Преобразователь DC/DC, Conv DC-DC 4.5V to 16V Step Down Dual-Out 0.5V to 1.8V 18A/18A uModule 144Pin BGA Tray | |||
| LTM4677IY#PBF Analog Devices | 2 260 ₽ | ||
| LTM4677IY#PBF Analog Devices | от 13 266 ₽ | ||
| LTM4677IY#PBF Analog Devices | по запросу | ||
| LTM4677IY Analog Devices | по запросу | ||
| Корпус | 16mm x 16mm x 5.01mm BGA |
| Код корпуса | BGA |
| Индекс корпуса | 05-08-1920 |
| ADC | 16-Bit |
| DAC | 12-Bit |
| Demo Boards | DC2066A,DC2143A-A,DC2143A-B,DC2143A-C,DC2481A-B,DC2481A-A,DC2204B |
| Design Tools | LTspice File,LTpowerCAD File,Linduino File |
| Экспортный контроль | нет |
| Основные особенности | Burst Mode, Differential Remote Sense, PolyPhase, PMBus, I2C Control, Watchdog Timer, EEPROM, ADC, DCR Current Sense, Sequencing, Margining, Tracking, External Synchronization |
| Function | DC/DC uModule Regulator With Power System Management |
| I/O | PMBus/SMBus/I2C |
| Isupply | 20 мА |
| Monitors | Vin, Iin, Vout, Iout, Temperature and Faults |
| Количество выходов | 2 |
| Диапазон напряжения питания | 4.5V to 16V |
| Vin Max | 16 В |
| Vin Min | 4.5 В |
- Accurate Temperature Sensing with an External P-N Junction &mdash AN137PDF, 540 Кб, Файл опубликован: 20 сен 2012
 Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.Выписка из документа
- Overview of the EEPROM in LTC PSM Devices &mdash AN145PDF, 3.0 Мб, Файл опубликован: 10 май 2014Выписка из документа
- Power System Management Addressing &mdash AN152PDF, 169 Кб, Файл опубликован: 12 июл 2016Выписка из документа
- Linduino for Power System Management &mdash AN153PDF, 1.3 Мб, Файл опубликован: 24 фев 2016Выписка из документа
- Fault Log Decoding with Linduino PSM &mdash AN155PDF, 230 Кб, Файл опубликован: 26 янв 2017Выписка из документа
- In Flight Update with Linduino &mdash AN166PDF, 1.1 Мб, Файл опубликован: 10 апр 2017Выписка из документа
- Implementing Fast Telemetry with Power System Management Controllers &mdash AN168PDF, 165 Кб, Файл опубликован: 8 фев 2018Выписка из документа
Статьи
- Avoid Debugging Cycles in Power Management for FPGA, GPU and ASIC Systems &mdash LT JournalPDF, 3.2 Мб, Файл опубликован: 25 авг 2016Выписка из документа
Серия: LTM4677 (3)
- LTM4677EY#PBF LTM4677IY LTM4677IY#PBF
- Monitor, Control and Protection > Digital Power System Management > DC/DC uModule With Power System Management
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- Power Management > Switching Regulator > Digitally Programmable Regulators
- µModule Solutions > µModule Regulators > µModule Buck Regulators
LTM4677IYPBF, LTM4677IY PBF
