Datasheet Linear Technology LT3952 — Даташит
СерияLT3952
60V LED Driver with 4A Switch Current
LT3952 - 60V LED Driver with 4A Switch Current
PDF, 1.2 Мб, Версия: B, Файл закачен: 4 окт 2017
40 предложений от 14 поставщиков
IC LED DRIVER 60V 4A 28TSSOP / LED Driver 2200uA Supply Current Automotive 28-Pin TSSOP EP Tube
LT3952AHFE#PBF
277 ₽
LT3952EFE#PBF
308 ₽
LT3952EFE#PBF
от 374 ₽
LT3952AIFE#TRPBF
491 ₽
LT3952EFE#PBFLT3952EFE#TRPBFLT3952HFE#PBFLT3952HFE#TRPBFLT3952IFE#PBFLT3952IFE#TRPBF
N123456
КорпусTSSOP-28
Габаритный чертеж корпуса
TSSOP-28
TSSOP-28
TSSOP-28
TSSOP-28
TSSOP-28
Код корпусаFEFEFEFEFEFE
Индекс корпуса05-08-1663 (EB)05-08-1663 (EB)05-08-1663 (EB)05-08-1663 (EB)05-08-1663 (EB)05-08-1663 (EB)
Количество выводов282828282828
Parameters / ModelsLT3952EFE#PBFLT3952EFE#TRPBFLT3952HFE#PBFLT3952HFE#TRPBFLT3952IFE#PBFLT3952IFE#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC2013A,DC2361ADC2013A,DC2361ADC2013A,DC2361ADC2013A,DC2361ADC2013A,DC2361ADC2013A,DC2361A
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Dimming4000:1 PWM, 20:1 Analog4000:1 PWM, 20:1 Analog4000:1 PWM, 20:1 Analog4000:1 PWM, 20:1 Analog4000:1 PWM, 20:1 Analog4000:1 PWM, 20:1 Analog
Экспортный контрольнетнетнетнетнетнет
Основные особенностиOpen LED Protection, Shorted LED Protection, Resistor Set Frequency, External Synchronization, Input Current Limit, Input Current Monitor, Spread SpectrumOpen LED Protection, Shorted LED Protection, Resistor Set Frequency, External Synchronization, Input Current Limit, Input Current Monitor, Spread SpectrumOpen LED Protection, Shorted LED Protection, Resistor Set Frequency, External Synchronization, Input Current Limit, Input Current Monitor, Spread SpectrumOpen LED Protection, Shorted LED Protection, Resistor Set Frequency, External Synchronization, Input Current Limit, Input Current Monitor, Spread SpectrumOpen LED Protection, Shorted LED Protection, Resistor Set Frequency, External Synchronization, Input Current Limit, Input Current Monitor, Spread SpectrumOpen LED Protection, Shorted LED Protection, Resistor Set Frequency, External Synchronization, Input Current Limit, Input Current Monitor, Spread Spectrum
Тактовая частота, kHz300030003000300030003000
Ishutdown, мкА353535353535
Isupply, мА1.51.51.51.51.51.5
Max Number of LEDsUp to 60VUp to 60VUp to 60VUp to 60VUp to 60VUp to 60V
Monolithicдададададада
Количество выходов111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85
Выходной ток, A444444
Switch Current, A4.54.54.54.54.54.5
Synchronousнетнетнетнетнетнет
TopologyLED Driver, Buck, Boost, Buck-BoostLED Driver, Buck, Boost, Buck-BoostLED Driver, Buck, Boost, Buck-BoostLED Driver, Buck, Boost, Buck-BoostLED Driver, Buck, Boost, Buck-BoostLED Driver, Buck, Boost, Buck-Boost
Vin Max, В424242424242
Vin Min, В333333
Vout Max, В606060606060
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
Design Notes
  • 3A, 1MHz Buck Mode LED Driver with Integrated Voltage Limiting &mdash DN556
    PDF, 344 Кб, Файл опубликован: 29 сен 2016
Статьи
  • Boost-Buck LED Driver Topology for Automotive LEDs Operates with Low Input and Output Ripple (LT3952) &mdash LT Journal
    PDF, 336 Кб, Файл опубликован: 7 апр 2015
  • One LED Driver Is All You Need for Automotive LED Headlight Clusters (LT3795) &mdash LT Journal
    PDF, 762 Кб, Файл опубликован: 7 июл 2015
  • Power Management > LED Driver ICs > Step-Up (Boost) LED Drivers | Step-Down (Buck) LED Drivers | Buck-Boost LED Drivers | Multitopology LED Driver
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) LED Drivers
На английском языке: Datasheet Linear Technology LT3952
