Datasheet LT1079CN - Linear Technology Даташит OP усилитель, QUAD PRECISION, 1079, DIP14 — Даташит
Наименование модели: LT1079CN
![]() 46 предложений от 22 поставщиков Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1079CN#PBF Operational Amplifier, Quad, 4 Amplifier, 200kHz, 0.07V/µs, 2.3V to 12V, DIP, 14Pins | |||
LT1079CN#PBF Analog Devices | 366 ₽ | ||
LT1079CN#PBF Linear Technology | 425 ₽ | ||
LT1079CN#PBF Analog Devices | от 1 148 ₽ | ||
LT1079CN#PBF | по запросу |
Производитель: Linear Technology
Описание: OP усилитель, QUAD PRECISION, 1079, DIP14
FEATURES
s s s s s s s s s s s
LT1078/LT1079 Micropower, Dual and Quad, Single Supply, Precision Op Amps DESCRIPTIO
The LT ® 1078 is a micropower dual op amp in 8-pin packages including the small outline surface mount package.
The LT1079 is a micropower quad op amp offered in the standard 14-pin packages. Both devices are optimized for single supply operation at 5V. ±15V specifications are also provided. Micropower performance of competing devices is achieved at the expense of seriously degrading precision, noise, speed and output drive specifications. The design effort of the LT1078/LT1079 was concentrated on reducing supply current without sacrificing other parameters. The offset voltage achieved is the lowest on any dual or quad nonchopper stabilized op amp--micropower or otherwise. Offset current, voltage and current noise, slew rate and gain bandwidth product are all two to ten times better than on previous micropower op amps. The 1/f corner of the voltage noise spectrum is at 0.
- Тип ОУ: Precision
- Количество усилителей: 4
- Полоса частот: 0.2 МГц
- Slew Rate: 0.07 В/мкс
- Диапазон напряжения питания: 2.3 В ... 12 В
- Amplifier Case Style: DIP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Тип усилителя: Precision
- Семейство: 1079
- Gain Bandwidth: 200 кГц
- IC Generic Number: 1079
- Рабочий диапазон температрур: Commercial
- Input Offset Voltage Max: 0.12 мВ
- Количество логических функций: 1079
- Особенности ОУ: Low Power
- Напряжение питания номинальное: 5 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK 14/16 B
- Fischer Elektronik - ICK 14/16 L
- Fischer Elektronik - WLK 5
