Datasheet Linear Technology LT1367CS#PBF — Даташит
СерияLT1367
МодельLT1367CS#PBF
Quad Precision Rail-to-Rail операционные усилители
Datasheet LT1366, LT1367, LT1368, LT1369
PDF, 396 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 20
Dual and Quad Precision Rail-to-Rail Input and Output Op Amps
45 предложений от 24 поставщиков
LT1367CS#PBF
423 ₽
Эиком
LT1367CS#TRPBF
от 1 887 ₽
ТаймЧипс
LT1367CS#PBF
LT1367CS
КорпусSO-14
Код корпусаS
Индекс корпуса05-08-1610 (S14)
Количество каналов4
Частота единичного усиления GBW0.4 МГц
Av Min Stable1 V/V
Avol66 дБ
CMRR106 дБ
Cload1000 пФ
Design ToolsLTspice Model
Enoise 1/f Corner1 Hz
Enoise Density29 нВ/rtГц
Экспортный контрольнет
Ibias10 нА
Inoise0.07 пА/rtГц
Inoise 1/f Corner3.5 Hz
Ios0.001 мкА
Iout75 мА
Isupply0.34 мА
Over-the-Topнет
PSRR105 дБ
Rail-to-RailBoth
Rail-to-Rail Inда
Rail-to-Rail Outда
SR0.13 В/мс
Shutdownнет
Single Supplyда
Ts (0.1%)30000 нс
ТипVFB
Voh (from V+)0.004 В
Vol (from V-)0.006 В
Vos0.15 мВ
Vos TC2 мВ/C
Vs макс.36 В
Vs мин.2 В
LT1366 LT1366 LT1368 LT1368 LT1369 LT1369
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
Design Notes
  • Applications of a Rail-to-Rail Amplifier &mdash DN89
    PDF, 77 Кб, Файл опубликован: 1 окт 1994
Серия: LT1367 (2)
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Low Power Amplifiers (Is < 1mA/amp) | Precision Amplifiers (Vos | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
LT1367CSPBF, LT1367CS PBF
На английском языке: Datasheet Linear Technology LT1367CS#PBF
Публикации по теме
