Datasheet LT1469CS8 - Linear Technology Даташит ИС, операционный усилитель, 90 МГц, 22 В/мкс, SOIC-8 — Даташит
Linear Technology LT1469CS8
Наименование модели: LT1469CS8
46 предложений от 23 поставщиков
Микросхема Операционный усилитель, LT1469 - Dual 90MHz, 22V/us 16Bit Accurate Operational Amplifier; Package: SO; Pins: 8; Temperature Range: 0°C to 70℃...
LT1469CS8#PBF
53 ₽
LT1469CS8#PBF
от 1 302 ₽
МосЧип
LT1469CS8-2-PBF
LifeElectronics
LT1469CS8-2#PBF
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 90 МГц, 22 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LT1469 Dual 90MHz, 22V/µs 16-Bit Accurate Operational Amplifier FEATURES
n n n n n n n n n n n n n n
DESCRIPTION
The LT®1469 is a dual, precision high speed operational amplifier with 16-bit accuracy and 900ns settling to 150V for 10V steps.
This unique blend of precision and AC performance makes the LT1469 the optimum choice for high accuracy applications such as DAC current-to-voltage conversion and ADC buffers. The initial accuracy and drift characteristics of the input offset voltage and inverting input bias current are tailored for inverting applications. The 90MHz gain bandwidth ensures high open-loop gain at frequency for reducing distortion. In noninverting applications such as an ADC buffer, the low distortion and DC accuracy allow full 16-bit AC and DC performance. The 22V/s slew rate of the LT1469 improves large signal performance compared to other precision op amps in applications such as active filters and instrumentation amplifiers. The LT1469 is available in a space sav
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 90 МГц
  • Slew Rate: 22 В/мкс
  • Диапазон напряжения питания: ± 4.5 В ... ± 15 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
Дополнительные аксессуары:
  • Linear Technology - LTC2634IMSE-HMX12#PBF.
  • Linear Technology - LTC2634IMSE-HZ12#PBF.
  • Linear Technology - LTC2634IUD-HZ12#PBF.
  • Linear Technology - LTC2634IUD-LMI12#PBF.
  • Linear Technology - LTC2634IUD-LZ12#PBF.
На английском языке: Datasheet LT1469CS8 - Linear Technology IC, OP-AMP, 90 MHz, 22 V/µs, SOIC-8
