Datasheet LT1101CN8 - Linear Technology Даташит ИС, усилитель INSTRUMENTATION, 1101, DIP8 — Даташит
Linear Technology LT1101CN8
Наименование модели: LT1101CN8
38 предложений от 17 поставщиков
Микросхема Усилитель прибора, LT1101 - Precision, Micropower, Single Supply Instrumentation Amplifier (Fixed Gain = 10 or 100); Package: PDIP; Pins: 8;...
LT1101CN8#PBF
от 477 ₽
LT1101CN8#PBF
от 1 428 ₽
LT1101CN8#PBF
Контест
LT1101CN8
Производитель: Linear Technology
Описание: ИС, усилитель INSTRUMENTATION, 1101, DIP8
data sheetСкачать Data Sheet
LT1101 Precision, Micropower, Single Supply Instrumentation Amplifier (Fixed Gain = 10 or 100) DESCRIPTIO
The LT®1101 establishes the following milestones: (1) It is the first micropower instrumentation amplifier, (2) It is the first single supply instrumentation amplifier, (3) It is the first instrumentation amplifier to feature fixed gains of 10 and/or 100 in low cost, space-saving 8-lead packages.
The LT1101 is completely self-contained: no external gain setting resistor is required. The LT1101 combines its micropower operation (75µA supply current) with a gain error of 0.008%, gain linearity of 3ppm, gain drift of 1ppm/°C. The output is guaranteed to drive a 2k load to ±10V with excellent gain accuracy. Other precision specifications are also outstanding: 50µV input offset voltage, 130pA input offset current, and low drift (0.4µV/°C and 0.7pA/°C). In addition, unlike other instrumentation amplifiers, there is no output offset voltage contribution to total error. A full set of speci
  • Количество усилителей: 1
  • Input Offset Voltage: 220 мкВ
  • Gain dB Min: 10 дБ
  • Gain dB Max: 100 дБ
  • Полоса частот: 37 кГц
  • Тип выхода: Single Ended / Differential
  • CMRR: 112 дБ
  • Slew Rate: 0.1 В/мкс
  • Диапазон напряжения питания: ± 1.1 В ... ± 18 В
  • Ток потребления: 94 мкА
  • Amplifier Case Style: DIP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Тип усилителя: Instrumentation
  • Семейство: 1101
  • Gain Bandwidth: 33 кГц
  • IC Generic Number: 1101
  • Рабочий диапазон температрур: Commercial
  • Input Offset Drift Max: 2.8µV/°C
  • Input Offset Voltage Max: 0.35 мВ
  • Количество логических функций: 1101
  • Особенности ОУ: Precision
  • Программируемое усиление максимум: 100
  • Программируемое усиление минимум: 10
  • Напряжение питания номинальное: 15 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 8 SA
  • Fischer Elektronik - WLK 5
  • Multicomp - 2227MC-08-03-18-F1
На английском языке: Datasheet LT1101CN8 - Linear Technology IC, AMP INSTRUMENTATION, 1101, DIP8
