Datasheet LT6700CS6-1 - Linear Technology Даташит Компаратор, 0.4VREF, 36VIN, 6TSOT23 — Даташит
Linear Technology LT6700CS6-1
Наименование модели: LT6700CS6-1
48 предложений от 25 поставщиков
IC COMP DUAL 400MV REF TSOT23-6. Comparator with Voltage Reference Open Collector TSOT-23-6. Linear - Comparators
LT6700CS6-1#TRM
64 ₽
Эиком
LT6700CS6-1#TRPBF
от 437 ₽
Hi-Tech Circuit Group
LT6700CS6-1#TRPBF
ТаймЧипс
LT6700CS6-1#TRPBF
Производитель: Linear Technology
Описание: Компаратор, 0.4VREF, 36VIN, 6TSOT23
data sheetСкачать Data Sheet
FEATURES
n n n n n n n n n n n n
LT6700-1/LT6700-2/LT6700-3/ LT6700HV-1/LT6700HV-2/ LT6700HV-3 Micropower, Low Voltage, Dual Comparator with 400mV Reference DESCRIPTION
The LT ® 6700-1/LT6700-2/LT6700-3/LT6700HV-1/ LT6700HV-2/LT6700HV-3 combine two micropower, low voltage comparators with a 400mV reference in a 6-lead SOT-23 or tiny DFN package.
Operating with supplies from 1.4V up to 18V, these devices draw only 6.5A, making them ideal for low voltage system monitoring. Hysteresis is included in the comparators, easing design requirements to insure stable output operation. The comparators each have one input available externally; the other inputs are connected internally to the reference. The comparator outputs are open collector and the output load can be referred to any voltage up to 18V (36V for LT6700HV), independent of supply voltage. The output stage sinking capability is guaranteed to be greater than 5mA over temperature. The three versions of this part differ by the polarity
  • Output Compatibility: CMOS
  • Время отклика: 29 мкс
  • Диапазон напряжения питания: 1.4 В ... 18 В
  • Количество выводов: 6
  • Количество компараторов: 2
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Семейство: 6700
  • Тип выхода: Open Collector
  • Тип компаратора: Micropower
  • Тип корпуса: TSOT-23
  • Ток потребления: 7.1 мкА
  • RoHS: да
  • SVHC: No SVHC (19-Dec-2011)
LT6700CS61, LT6700CS6 1
На английском языке: Datasheet LT6700CS6-1 - Linear Technology COMPARATOR, 0.4VREF, 36VIN, 6TSOT23
