Datasheet LT6700CS6-3 - Linear Technology Даташит Компаратор, UP, 400 мВ REF, SOT23-6 — Даташит
Linear Technology LT6700CS6-3
Наименование модели: LT6700CS6-3
52 предложений от 28 поставщиков
IC COMP DUAL 400MV REF TSOT23-6. Comparator with Voltage Reference Open Collector TSOT-23-6. Linear - Comparators
LT6700CS6-3#TRMPBF
353 ₽
Элитан
LT6700CS6-3
403 ₽
Hi-Tech Circuit Group
LT6700CS6-3#TRPBF
LT6700CS6-3-TRMPBF
Производитель: Linear Technology
Описание: Компаратор, UP, 400 мВ REF, SOT23-6
data sheetСкачать Data Sheet
FEATURES
n n n n n n n n n n n n
LT6700-1/LT6700-2/LT6700-3/ LT6700HV-1/LT6700HV-2/ LT6700HV-3 Micropower, Low Voltage, Dual Comparator with 400mV Reference DESCRIPTION
The LT ® 6700-1/LT6700-2/LT6700-3/LT6700HV-1/ LT6700HV-2/LT6700HV-3 combine two micropower, low voltage comparators with a 400mV reference in a 6-lead SOT-23 or tiny DFN package.
Operating with supplies from 1.4V up to 18V, these devices draw only 6.5A, making them ideal for low voltage system monitoring. Hysteresis is included in the comparators, easing design requirements to insure stable output operation. The comparators each have one input available externally; the other inputs are connected internally to the reference. The comparator outputs are open collector and the output load can be referred to any voltage up to 18V (36V for LT6700HV), independent of supply voltage. The output stage sinking capability is guaranteed to be greater than 5mA over temperature. The three versions of this part differ by the polarity
  • Тип компаратора: Low Voltage
  • Количество компараторов: 2
  • Время отклика: 18 мкс
  • Тип выхода: CMOS, MOS, Open-Collector / Drain, TTL
  • Ток потребления: 7.1 мкА
  • Диапазон напряжения питания: 1.4 В ... 18 В
  • Тип корпуса: SOT-23
  • Количество выводов: 6
  • Рабочий диапазон температрур: 0°C ... +70°C
  • SVHC: No SVHC (19-Dec-2011)
  • Семейство: 6700
  • Способ монтажа: SMD
LT6700CS63, LT6700CS6 3
На английском языке: Datasheet LT6700CS6-3 - Linear Technology COMPARATOR, UP, 400 mV REF, SOT23-6
