Datasheet Linear Technology LTC6908 — Даташит
| Серия | LTC6908 |
Генератор с двумя выходами и модуляцией расширенного спектра
LTC6908-1/LTC6908-2 - Resistor Set SOT-23 Oscillator with Spread Spectrum Modulation
PDF, 254 Кб, Версия: A
|  Купить LTC6908 на РадиоЛоцман.Цены — от 444 до 2 612 ₽ 17 предложений от 16 поставщиков , Spread Spectrum Silicon Oscillator 0.05MHz to 10MHz CMOS/Squarewave Automotive 6Pin TSOT-23 | |||
| LTC6908CS6-1 Linear Technology | от 696 ₽ | ||
| LTC6908IS6-1 | по запросу | ||
| LTC6908IS6-1 Analog Devices | по запросу | ||
| LTC6908CS6-2 Analog Devices | по запросу | ||
| LTC6908CDCB-1#PBF | LTC6908CDCB-1#TRMPBF | LTC6908CDCB-1#TRPBF | LTC6908CDCB-2#PBF | LTC6908CDCB-2#TRMPBF | LTC6908CDCB-2#TRPBF | LTC6908CS6-1#PBF | LTC6908CS6-1#TRMPBF | LTC6908CS6-1#TRPBF | LTC6908CS6-2#PBF | LTC6908CS6-2#TRMPBF | LTC6908CS6-2#TRPBF | LTC6908HS6-1#PBF | LTC6908HS6-1#TRMPBF | LTC6908HS6-1#TRPBF | LTC6908HS6-2#PBF | LTC6908HS6-2#TRMPBF | LTC6908HS6-2#TRPBF | LTC6908IDCB-1#PBF | LTC6908IDCB-1#TRMPBF | LTC6908IDCB-1#TRPBF | LTC6908IDCB-2#PBF | LTC6908IDCB-2#TRMPBF | LTC6908IDCB-2#TRPBF | LTC6908IS6-1#PBF | LTC6908IS6-1#TRMPBF | LTC6908IS6-1#TRPBF | LTC6908IS6-2#PBF | LTC6908IS6-2#TRMPBF | LTC6908IS6-2#TRPBF | |
| N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 |
| Корпус | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | 2x3 DFN-6 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOT-23 |
| Код корпуса | DCB | DCB | DCB | DCB | DCB | DCB | S6 | S6 | S6 | S6 | S6 | S6 | S6 | S6 | S6 | S6 | S6 | S6 | DCB | DCB | DCB | DCB | DCB | DCB | S6 | S6 | S6 | S6 | S6 | S6 |
| Parameters / Models | LTC6908CDCB-1#PBF | LTC6908CDCB-1#TRMPBF | LTC6908CDCB-1#TRPBF | LTC6908CDCB-2#PBF | LTC6908CDCB-2#TRMPBF | LTC6908CDCB-2#TRPBF | LTC6908CS6-1#PBF | LTC6908CS6-1#TRMPBF | LTC6908CS6-1#TRPBF | LTC6908CS6-2#PBF | LTC6908CS6-2#TRMPBF | LTC6908CS6-2#TRPBF | LTC6908HS6-1#PBF | LTC6908HS6-1#TRMPBF | LTC6908HS6-1#TRPBF | LTC6908HS6-2#PBF | LTC6908HS6-2#TRMPBF | LTC6908HS6-2#TRPBF | LTC6908IDCB-1#PBF | LTC6908IDCB-1#TRMPBF | LTC6908IDCB-1#TRPBF | LTC6908IDCB-2#PBF | LTC6908IDCB-2#TRMPBF | LTC6908IDCB-2#TRPBF | LTC6908IS6-1#PBF | LTC6908IS6-1#TRMPBF | LTC6908IS6-1#TRPBF | LTC6908IS6-2#PBF | LTC6908IS6-2#TRMPBF | LTC6908IS6-2#TRPBF |
| Frequency Accuracy, % | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
| Диапазон частот | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz | 50kHz to 10MHz |
| Function | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator | Oscillator |
| Isupply, мА | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 |
| Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
| Program Method | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor | Resistor |
| RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC6908 (30)
- LTC6908CDCB-1#PBF LTC6908CDCB-1#TRMPBF LTC6908CDCB-1#TRPBF LTC6908CDCB-2#PBF LTC6908CDCB-2#TRMPBF LTC6908CDCB-2#TRPBF LTC6908CS6-1#PBF LTC6908CS6-1#TRMPBF LTC6908CS6-1#TRPBF LTC6908CS6-2#PBF LTC6908CS6-2#TRMPBF LTC6908CS6-2#TRPBF LTC6908HS6-1#PBF LTC6908HS6-1#TRMPBF LTC6908HS6-1#TRPBF LTC6908HS6-2#PBF LTC6908HS6-2#TRMPBF LTC6908HS6-2#TRPBF LTC6908IDCB-1#PBF LTC6908IDCB-1#TRMPBF LTC6908IDCB-1#TRPBF LTC6908IDCB-2#PBF LTC6908IDCB-2#TRMPBF LTC6908IDCB-2#TRPBF LTC6908IS6-1#PBF LTC6908IS6-1#TRMPBF LTC6908IS6-1#TRPBF LTC6908IS6-2#PBF LTC6908IS6-2#TRMPBF LTC6908IS6-2#TRPBF
- Timing > Silicon Oscillators | Extended Temperature (H & MP) Timing
