Клеммники KEEN SIDE
Datasheet LT1964ES5-BYP - Linear Technology Даташит LDO REG, 200 мА, LN, NEG, TSOT23-5 — Даташит
Linear Technology LT1964ES5-BYP
Наименование модели: LT1964ES5-BYP
Чип стабилизации напряжения, LT1964 - 200mA, Low Noise, Low Dropout Negative Micropower Regulator
LT1964ES5-BYP
150 ₽
LT1964ES5-BYP
LT1964ES5BYP#TRMPBF
LT1964ES5BYP
Производитель: Linear Technology
Описание: LDO REG, 200 мА, LN, NEG, TSOT23-5
data sheetСкачать Data Sheet
LT1964 200mA, Low Noise, Low Dropout Negative Micropower Regulator FEATURES
n n n n n n n n n n n n
DESCRIPTION
The LT®1964 is a micropower low noise, low dropout negative regulator.
The device is capable of supplying 200mA of output current with a dropout voltage of 340mV. Low quiescent current (30A operating and 3A shutdown) makes the LT1964 an excellent choice for battery-powered applications. Quiescent current is well controlled in dropout. Other features of the LT1964 include low output noise. With the addition of an external 0.01F bypass capacitor, output noise is reduced to 30VRMS over a 10Hz to 100kHz bandwidth. The LT1964 is capable of operating with small capacitors and is stable with output capacitors as low as 1F Small ceramic capacitors can be used without . the necessary addition of ESR as is common with other regulators. Internal protection circuitry includes reverse output protection, current limiting, and thermal limiting. The device is available with a fixed output v
  • Output Voltage Adjustable Range: -1.22 В ... -20 В
  • Dropout Voltage Vdo: 340 мВ
  • Количество выводов: 5
  • Выходной ток: 200 мА
  • Тип корпуса: SOT-23
  • Рабочий диапазон температрур: -40°C ... +125°C
  • SVHC: No SVHC (15-Dec-2010)
  • Семейство: 1964
  • Входное напряжение максимальное: -20 В
  • Количество выходов: 1
  • Выходной ток максимальный: 200 мА
  • Выходное напряжение: -20 В
  • Выходное напряжение максимальное: -20 В
  • Способ монтажа: SMD
  • Тип стабилизатора: LDO Adjustable Negative
  • Диапазон напряжения питания: -2.8 В ... -20 В
LT1964ES5BYP, LT1964ES5 BYP
На английском языке: Datasheet LT1964ES5-BYP - Linear Technology LDO REG, 200 mA, LN, NEG, TSOT23-5
