Datasheet Linear Technology LT1027CCS8-5#TRPBF — Даташит
СерияLT1027CCS8-5
МодельLT1027CCS8-5#TRPBF
Прецизионный опорный сигнал 5 В
Datasheet LT1027
PDF, 220 Кб, Язык: анг., Файл закачен: 12 авг 2017, Страниц: 8
Precision 5 Volt Reference
31 предложений от 14 поставщиков
Опорный чип напряжения, V-Ref Precision 5V 15mA 8Pin SOIC N T/R
LT1027CCS8-5#TRPBF
384 ₽
LT1027CCS8-5#TRPBF
462 ₽
LT1027CCS8-5#TRPBF
ЗУМ-СМД
LT1027CCS8-5#TRPBF
КорпусSO-8
Код корпусаS8
Индекс корпуса05-08-1610 (S8)
Экспортный контрольнет
Initial Accuracy0.05 %
Line Reg6 ppm/V
Load Reg-3 ppm/mA
Low Freq Noise3 µVPP
Min Vin/Vout Differential3 В
Диапазон выходных токов-10 to 15mA
Quiescent or Min Shunt Current2200 мкА
Ref Vout5 В
Series/ShuntSeries
Temp Co2 ppm/В°C
Vin Max40 В
LT1027 LT1027BCN8-5 LT1027CCN8-5 LT1027DCN8-5 LT1027DCS8-5 LT1027ECN8-5 LT1027ECS8-5
  • Voltage Reference Circuit Collection &mdash AN42
    PDF, 1.7 Мб, Файл опубликован: 1 июн 1991
    A wide variety of voltage reference circuits are detailed in this extensive guidebook of circuits. The detailed schematics cover simple and precision approaches at a variety of power levels. Included are 2 and 3 terminal devices in series and shunt modes for positive and negative polarities. Appended sections cover resistor and capacitor selection and trimming techniques.
  • Data Acquisition Circuit Collection &mdash AN62
    PDF, 349 Кб, Файл опубликован: 1 окт 1994
    This application note presents a wide variety of data acquisition circuits. The detailed circuit schematics cover 8-, 10-, and 12- bit ADC and DAC applications, serial and parallel digital interfaces, battery monitoring, temperature sensing, isolated interfaces, and connections to various popular microprocessors and microcontrollers. An appendix covers suggested voltage references.
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time &mdash AN74
    PDF, 980 Кб, Файл опубликован: 1 июл 1998
    DAC DC specifications are relatively easy to verify. AC specifications require more sophisticated approaches to produce reliable information. In particular, the settling time of the DAC and its output amplifier is extraordinarily difficult to determine to 16-bit resolution. This application note presents methods for 16-bit DAC settling time measurement and compares results. Appendices discuss oscilloscope overdrive, frequency compensation, circuit and optimization techniques, layout, power stages and a historical perspective of precision DACs.
  • Understanding and Applying Voltage References &mdash AN82
    PDF, 172 Кб, Файл опубликован: 1 ноя 1999
    Just how do bandgaps and buried Zeners stack up against Weston cells? Did you know your circuit board may induce more drift in a reference than time and temperature? Learn the answers to these and other commonly asked reference questions ranging from burn-in recommendations to ΔVBE generation in this Application Note.
  • A Standards Lab Grade 20-Bit DAC with 0.1ppm/В° Drift: The Dedicated Art of Digitizing One Part Per Million &mdash AN86
    PDF, 540 Кб, Файл опубликован: 1 янв 2001
    This publication details a true 1ppm D-to-A converter. Total DC error of this processor corrected DAC remains within 1ppm from 18-32°C, including reference drift. DAC error exclusive of reference drift is substantially better. Construction details and performance verification techniques are included, along with a complete software listing.
Design Notes
  • Signal Conditioning for Platinum Temperature Transducers &mdash DN45
    PDF, 69 Кб, Файл опубликован: 1 мар 1991
  • Gain Trimming In Instrumentation Amplifier Based Systems &mdash DN51
    PDF, 78 Кб, Файл опубликован: 1 июн 1991
Статьи
  • Component and Measurement Advances Ensure 16-Bit DAC Settling Time (Part One) &mdash LT Journal
    PDF, 262 Кб, Файл опубликован: 1 авг 1998
  • How to Choose a Voltage Reference &mdash LT Journal
    PDF, 282 Кб, Файл опубликован: 1 мар 2009
Серия: LT1027CCS8-5 (2)
  • Signal Conditioning > Voltage References > Series Voltage References
LT1027CCS8-5TRPBF, LT1027CCS8-5 TRPBF, LT1027CCS85#TRPBF, LT1027CCS8 5#TRPBF
На английском языке: Datasheet Linear Technology LT1027CCS8-5#TRPBF
