Datasheet MAX4460ESA+ - Maxim Даташит ИС, INST усилитель, HIGH PRECISION — Даташит
Наименование модели: MAX4460ESA+
![]() 34 предложений от 21 поставщиков Микросхема Буферный усилитель, SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers | |||
MAX4460ESA+ Analog Devices | от 510 ₽ | ||
MAX4460ESA+ Maxim | по запросу | ||
MAX4460ESA+ | по запросу | ||
MAX4460ESA Maxim | по запросу |
Производитель: Maxim
Описание: ИС, INST усилитель, HIGH PRECISION
19-2279; Rev 4; 3/06
SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers MAX4460/MAX4461/MAX4462
General Description
The MAX4460/MAX4461/MAX4462 are instrumentation amplifiers with precision specifications, low-power consumption, and excellent gain-bandwidth product.
Proprietary design techniques allow ground-sensing capability combined with ultra-low input current and increased common-mode rejection performance. These rail-to-rail output instrumentation amplifiers are offered in fixed or adjustable gains and the option for either a shutdown mode or a pin to set the output voltage relative to an external reference (see the Ordering Information and Selector Guide). The MAX4460 has an adjustable gain and uses ground as its reference voltage. The MAX4461 is offered in fixed gains of 1, 10, and 100, uses ground as its reference voltage, and has a logic-controlled shutdown input. The MAX4462 is offered in fixed gains of 1, 10, and 100 and has a reference input pin (REF). R
- Количество усилителей: 1
- Input Offset Voltage: 425 мкВ
- Gain dB Min: 1 дБ
- Gain dB Max: 10 дБ
- Полоса частот: 2.5 МГц
- Тип выхода: Single Ended
- CMRR: 120 дБ
- Slew Rate: 0.5 В/мкс
- Диапазон напряжения питания: 2.85 В ... 5.25 В
- Ток потребления: 800 мкА
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SO
- Семейство: 4460
- Input Offset Drift Max: 1.5µV/°C
- Input Offset Voltage Max: 425 мкВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 6 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- BONKOTE - BON102
- Roth Elektronik - RE932-01
