Datasheet Linear Technology LTC1696ES6#TRMPBF — Даташит
СерияLTC1696
МодельLTC1696ES6#TRMPBF
Контроллер защиты от перенапряжения
Datasheet LTC1696
PDF, 178 Кб, Язык: анг., Файл закачен: 25 окт 2017, Страниц: 14
Overvoltage Protection Controller
34 предложений от 16 поставщиков
Контрольный чип источника питания, Volt Supervisor Monitor 3.3V/5V 6Pin TSOT-23 T/R
LTC1696ES6#TRMPBF
от 99 ₽
LTC1696ES6#TRMPBF
от 181 ₽
LTC1696ES6#TRMPBF
184 ₽
Эиком
LTC1696ES6#TRMPBF
от 584 ₽
КорпусSOT-23
Код корпусаS6
Индекс корпуса05-08-1636
Количество каналов2
Design ToolsLTspice Model
Экспортный контрольнет
Fault Ride Through Timerда
FunctionOV Disconnect
Рабочий диапазон температурот 0 до 85 °C
Overvoltage Threhold Accuracy2 %
Reverse VinN/A
Total Quiescent Current0.17 мА
Vin Range0.8V to 24V
  • Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90
    PDF, 409 Кб, Файл опубликован: 1 апр 2002
    A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.
  • Monitor, Control and Protection > Surge Stopper, Overvoltage & Overcurrent Protection
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
LTC1696ES6TRMPBF, LTC1696ES6 TRMPBF
На английском языке: Datasheet Linear Technology LTC1696ES6#TRMPBF
Публикации по теме
