Datasheet Linear Technology LTC1696ES6#TRPBF — Даташит
| Серия | LTC1696 |
| Модель | LTC1696ES6#TRPBF |
Контроллер защиты от перенапряжения
Datasheet LTC1696
PDF, 178 Кб, Язык: анг., Файл закачен: 25 окт 2017, Страниц: 14
Overvoltage Protection Controller
|  Купить LTC1696ES6#TRPBF на РадиоЛоцман.Цены — от 75 до 857 ₽ 36 предложений от 17 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Контроллеры источников питания | |||
| LTC1696ES6#TRPBF | от 663 ₽ | ||
| LTC1696ES6#TRPBF | по запросу | ||
| LTC1696ES6#TRPBF Analog Devices | по запросу | ||
| Корпус | SOT-23 |
| Код корпуса | S6 |
| Индекс корпуса | 05-08-1636 |
| Количество каналов | 2 |
| Design Tools | LTspice Model |
| Экспортный контроль | нет |
| Fault Ride Through Timer | да |
| Function | OV Disconnect |
| Рабочий диапазон температур | от 0 до 85 °C |
| Overvoltage Threhold Accuracy | 2 % |
| Reverse Vin | N/A |
| Total Quiescent Current | 0.17 мА |
| Vin Range | 0.8V to 24V |
- Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90PDF, 409 Кб, Файл опубликован: 1 апр 2002
 A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.Выписка из документа
Серия: LTC1696 (9)
- Monitor, Control and Protection > Surge Stopper, Overvoltage & Overcurrent Protection
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
LTC1696ES6TRPBF, LTC1696ES6 TRPBF
