Datasheet Linear Technology LTC1696IS6#TRPBF — Даташит
СерияLTC1696
МодельLTC1696IS6#TRPBF
Контроллер защиты от перенапряжения
Datasheet LTC1696
PDF, 178 Кб, Язык: анг., Файл закачен: 25 окт 2017, Страниц: 14
Overvoltage Protection Controller
12 предложений от 10 поставщиков
, Overvoltage Protection Controller
LTC1696IS6#TRPBF
82 ₽
LTC1696IS6#TRPBF
184 ₽
LTC1696IS6#TRPBF
LTC1696IS6#TRPBF
КорпусSOT-23
Код корпусаS6
Индекс корпуса05-08-1636
Количество каналов2
Design ToolsLTspice Model
Экспортный контрольнет
Fault Ride Through Timerда
FunctionOV Disconnect
Overvoltage Threhold Accuracy2 %
Reverse VinN/A
Total Quiescent Current0.17 мА
Vin Range0.8V to 24V
  • Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90
    PDF, 409 Кб, Файл опубликован: 1 апр 2002
    A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.
  • Monitor, Control and Protection > Surge Stopper, Overvoltage & Overcurrent Protection
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
LTC1696IS6TRPBF, LTC1696IS6 TRPBF
На английском языке: Datasheet Linear Technology LTC1696IS6#TRPBF
Публикации по теме
