Datasheet MAX985ESA+ - Maxim Даташит ИС, COMPARATOR, MICROPOWER, SINGLE — Даташит
Наименование модели: MAX985ESA+
![]() 26 предложений от 19 поставщиков MAXIM INTEGRATED PRODUCTS MAX985ESA+ Analog Comparator, Rail to Rail, Micropower, 1, 300ns, 2.5V to 5.5V, ± 1.25V to ± 2.75V, NSOIC... | |||
MAX985ESA+ Maxim | 168 ₽ | ||
MAX985ESA Analog Devices | 218 ₽ | ||
MAX985ESA Maxim | 289 ₽ | ||
MAX985-ESA-719 Maxim | по запросу |
Производитель: Maxim
Описание: ИС, COMPARATOR, MICROPOWER, SINGLE
19-1229; Rev 4; 1/07
Micropower, Low-Voltage, UCSP/SC70, Rail-to-Rail I/O Comparators
General Description
The MAX985/MAX986/MAX989/MAX990/MAX993/ MAX994 single/dual/quad micropower comparators feature low-voltage operation and rail-to-rail inputs and outputs.
Their operating voltages range from 2.5V to 5.5V, making them ideal for both 3V and 5V systems. These comparators also operate with ±1.25V to ±2.75V dual supplies. They consume only 11µA of supply current while achieving a 300ns propagation delay. Input bias current is typically 1.0pA, and input offset voltage is typically 0.5mV. Internal hysteresis ensures clean output switching, even with slow-moving input signals. The output stage's unique design limits supply-current surges while switching, virtually eliminating the supply glitches typical of many other comparators. The MAX985/MAX989/MAX993 have a push-pull output stage that sinks as well as sources current. Large internal output drivers allow rail-to-rail output swing with l
- Тип компаратора: Low Voltage
- Количество компараторов: 1
- Время отклика: 300 нс
- Тип выхода: CMOS, MOS, Open-Collector / Drain, TTL
- Ток потребления: 12µ А
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SO
- Семейство: 985
- Количество каналов: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
Дополнительные аксессуары:
- Electrolube - SMA10SL
