Datasheet MAX985EUK+T - Maxim Даташит Компаратор, RRIO, 5.5VIN, 5SOT23 — Даташит
Наименование модели: MAX985EUK+T
![]() 49 предложений от 23 поставщиков Микросхема Компаратор, MAXIM INTEGRATED PRODUCTS MAX985EUK+T. Analogue Comparator, Rail to Rail, Low Voltage, 1, 300ns, 2.5V to 5.5V, SOT-23, 5Pins | |||
MAX985EUK+T Maxim | 36 ₽ | ||
MAX985EUK+T Maxim | 136 ₽ | ||
MAX985EUK+T Analog Devices | от 613 ₽ | ||
MAX985EUKT Maxim | по запросу |
Производитель: Maxim
Описание: Компаратор, RRIO, 5.5VIN, 5SOT23
19-1229; Rev 4; 1/07
Micropower, Low-Voltage, UCSP/SC70, Rail-to-Rail I/O Comparators
General Description
The MAX985/MAX986/MAX989/MAX990/MAX993/ MAX994 single/dual/quad micropower comparators feature low-voltage operation and rail-to-rail inputs and outputs.
Their operating voltages range from 2.5V to 5.5V, making them ideal for both 3V and 5V systems. These comparators also operate with ±1.25V to ±2.75V dual supplies. They consume only 11µA of supply current while achieving a 300ns propagation delay. Input bias current is typically 1.0pA, and input offset voltage is typically 0.5mV. Internal hysteresis ensures clean output switching, even with slow-moving input signals. The output stage's unique design limits supply-current surges while switching, virtually eliminating the supply glitches typical of many other comparators. The MAX985/MAX989/MAX993 have a push-pull output stage that sinks as well as sources current. Large internal output drivers allow rail-to-rail output swing with l
- Влагостойкость: MSL 1 - Unlimited
- Время отклика: 300 нс
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Количество выводов: 5
- Количество компараторов: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип выхода: Push Pull
- Тип компаратора: Low Voltage
- Тип корпуса: SOT-23
- Ток потребления: 12 мкА
- RoHS: да
