Datasheet MAX9012EUA+ - Maxim Даташит Компаратор, сдвоенный, 5.5VIN, 8µMAX — Даташит
Наименование модели: MAX9012EUA+
Купить MAX9012EUA+ на РадиоЛоцман.Цены — от 65 до 722 ₽43 предложений от 23 поставщиков Микросхема Компаратор, MAXIM INTEGRATED PRODUCTS MAX9012EUA+. Analogue Comparator, Dual, High Speed, 2, 5ns, 4.5V to 5.5V, µMAX, 8Pins | |||
| MAX9012EUA+T Maxim | 167 ₽ | ||
| MAX9012EUA+ Maxim | 251 ₽ | ||
| MAX9012EUA+ Analog Devices | 722 ₽ | ||
| MAX9012EUA+T Maxim | по запросу | ||
Производитель: Maxim
Описание: Компаратор, сдвоенный, 5.5VIN, 8µMAX
19-1932; Rev 1; 1/02
SC70, 5ns, Low-Power, Single-Supply, Precision TTL Comparators
General Description
The MAX9010/MAX9011/MAX9013 single and MAX9012 dual, high-speed comparators operate from a single 4.5V to 5.5V power supply and feature low-current consumption.
They have precision differential inputs and TTL outputs. They feature short propagation delay (5ns, typ), low-supply current, and a wide common-mode input range that includes ground. They are ideal for lowpower, high-speed, single-supply applications. The comparator outputs remain stable through the linear region when driven with slow-moving or low input-overdrive signals, eliminating the output instability common to other high-speed comparators. The input voltage range extends to 200mV below ground with no output phase reversal. The MAX9013 features complementary outputs and both the MAX9011/MAX9013 have a latch enable input (LE). The MAX9013 is an improved plug-in replacement for the industry-standard MAX913 and LT1016/LT1
- Output Compatibility: TTL
- Влагостойкость: MSL 1 - Unlimited
- Время отклика: 5 нс
- Диапазон напряжения питания: 4.5 В ... 5.5 В
- Количество выводов: 8
- Количество компараторов: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип выхода: Push Pull
- Тип компаратора: High Speed
- Тип корпуса: µMAX
- Ток потребления: 2.4 мА
- RoHS: да
