Datasheet Linear Technology LTC1154 — Даташит
СерияLTC1154
Высокочастотный микромощный драйвер MOSFET
LTC1154 - High-Side Micropower MOSFET Driver
PDF, 275 Кб, Версия: C, Файл закачен: 26 окт 2017
23 предложений от 20 поставщиков
High Side Micropower MOSFET Driver Fully Enhances N-Channel Power MOSFETs
LTC1154CS8
167 ₽
LTC1154CS8
170 ₽
LTC1154HS8
LTC1154C
LTC1154CN8#PBFLTC1154CS8#PBFLTC1154CS8#TRPBFLTC1154HS8#PBFLTC1154HS8#TRPBF
N12345
КорпусN-8
Габаритный чертеж корпуса
SO-8
SO-8
SO-8
SO-8
Код корпусаNS8S8S8S8
Индекс корпуса05-08-1510 (N8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)
Количество выводов88888
Parameters / ModelsLTC1154CN8#PBFLTC1154CS8#PBFLTC1154CS8#TRPBFLTC1154HS8#PBFLTC1154HS8#TRPBF
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice Model
Экспортный контрольнетнетнетнетнет
FunctionMOSFET DriverMOSFET DriverMOSFET DriverMOSFET DriverMOSFET Driver
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70от -40 до 125от -40 до 125
Switches11111
Vin Max, В2222222222
Vin Range4.5 to 184.5 to 184.5 to 184.5 to 184.5 to 18
RoHSСовместимСовместимСовместимСовместимСовместим
  • Micropower High Side MOSFET Drivers &mdash AN53
    PDF, 226 Кб, Файл опубликован: 3 янв 1993
    This application note describes the operation of high-side Nchannel MOSFET switch drivers designed specifically for operation in battery-powered equipment, such as notebook and palmtop computers and portable medical instruments. A selection guide simplifies the proper choice of MOSFET and driver for a particular high-side switch application. Circuits to drive and protect load impedances ranging from large inductors to large capacitors are described and a section on surface mount and copper clad shunts is included.
  • Monitor, Control and Protection > High Side Switches & MOSFET Drivers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
На английском языке: Datasheet Linear Technology LTC1154
