Datasheet Linear Technology LTC1157 — Даташит
СерияLTC1157
3,3 В Двойной микромощный драйвер MOSFET верхнего/низкого плеча
LTC1157 - 3.3V Dual Micropower High-Side/Low-Side MOSFET Driver
PDF, 206 Кб, Файл закачен: 26 окт 2017
LTC1157CN8#PBFLTC1157CS8#PBFLTC1157CS8#TRPBF
N123
КорпусN-8
Габаритный чертеж корпуса
SO-8
SO-8
Код корпусаNS8S8
Индекс корпуса05-08-1510 (N8)05-08-1610 (S8)05-08-1610 (S8)
Количество выводов888
Parameters / ModelsLTC1157CN8#PBFLTC1157CS8#PBFLTC1157CS8#TRPBF
Design ToolsLTspice ModelLTspice ModelLTspice Model
Экспортный контрольнетнетнет
FunctionDual 3.3V High Side DriverDual 3.3V High Side DriverDual 3.3V High Side Driver
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70
Switches222
Vin Max, В777
Vin Range2.7 to 72.7 to 72.7 to 7
  • Power Conditioning for Notebook and Palmtop Systems &mdash AN51
    PDF, 260 Кб, Файл опубликован: 3 авг 1992
    Notebook and palmtop systems need a number of voltages developed from a battery. Competitive solutions require small size, high efficiency and light weight. This publication includes circuits for high efficiency 5V and 3.3V switching and linear regulators, back light display drivers and battery chargers. All the circuits are specifically tailored for the requirements outlined above.
  • Micropower High Side MOSFET Drivers &mdash AN53
    PDF, 226 Кб, Файл опубликован: 3 янв 1993
    This application note describes the operation of high-side Nchannel MOSFET switch drivers designed specifically for operation in battery-powered equipment, such as notebook and palmtop computers and portable medical instruments. A selection guide simplifies the proper choice of MOSFET and driver for a particular high-side switch application. Circuits to drive and protect load impedances ranging from large inductors to large capacitors are described and a section on surface mount and copper clad shunts is included.
  • Linear Technology Magazine Circuit Collection, Volume II &mdash AN66
    PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
    Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.
Design Notes
  • Regulator Circuit Generates Both 3.3V and 5V Outputs from 3.3V or 5V to Run Computers and RS232 &mdash DN71
    PDF, 89 Кб, Файл опубликован: 1 июн 1993
  • PC Card Power Management Techniques &mdash DN76
    PDF, 77 Кб, Файл опубликован: 1 ноя 1993
  • Monitor, Control and Protection > High Side Switches & MOSFET Drivers
На английском языке: Datasheet Linear Technology LTC1157
Политика конфиденциальности
