Datasheet Microchip AT32UC3L0128-ZAUR — Даташит
Производитель | Microchip |
Серия | AT32UC3L0128 |
Модель | AT32UC3L0128-ZAUR |
The high-performance 32-bit AVRВ® UC3 RISC microcontroller is designed for cost-sensitive embedded applications that require low power consumption, high code density, and high performance.
![]() 9 предложений от 9 поставщиков Микросхема Микроконтроллер 32, MCU 32Bit AT32 AVR RISC 128KB Flash 1.8V 48Pin QFN T/R | |||
AT32UC3L0128-ZAUR Microchip | 186 ₽ | ||
AT32UC3L0128-ZAUR Atmel | 434 ₽ | ||
AT32UC3L0128-ZAUR Atmel | 450 ₽ | ||
AT32UC3L0128-ZAUR Atmel | по запросу |
Корпус | VQFN |
Количество выводов | 48 |
# of Comparators | 8 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit AVR |
CRC/Scan | No |
Cap. Touch Channels | 17 |
Configurable Logic Cell Modules | 1 CLC |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 120Mhz, 8Mhz, 115Khz |
Math Accelerator | No |
Max # PWM outputs | 35 including complementary outputs |
Max 16 Bit Digital Timers | 6 |
Max. CPU Speed MHz | 50 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 48 |
Размер памяти программ | 128 Kbytes |
RAM | 32768 bytes |
SPIв„ў | 5 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 8 |
UART | 4 |
Zero Cross detect | No |
AT32UC3A0128 AT32UC3A0256 AT32UC3A0512 AT32UC3A1128 AT32UC3A1256 AT32UC3A1512 AT32UC3A3128 AT32UC3A3128S AT32UC3A3256 AT32UC3A3256S AT32UC3A364 AT32UC3A364S AT32UC3A4128 AT32UC3A4128S AT32UC3A4256 AT32UC3A4256S AT32UC3A464 AT32UC3A464S AT32UC3B0128 AT32UC3B0256 AT32UC3B0512 AT32UC3B064 AT32UC3B1128 AT32UC3B1256 AT32UC3B1512 AT32UC3B164 AT32UC3C0128C AT32UC3C0256C AT32UC3C0512C AT32UC3C0512C-AUTOMOTIVE AT32UC3C064C AT32UC3C1128C AT32UC3C1256C AT32UC3C1512C AT32UC3C1512C-AUTOMOTIVE AT32UC3C164C AT32UC3C2128C AT32UC3C2256C AT32UC3C2512C AT32UC3C2512C-AUTOMOTIVE AT32UC3C264C AT32UC3L0256 ATUC128D3 ATUC128L3U ATUC128L4U ATUC256L3U ATUC256L4U ATUC64D3 ATUC64D4 ATUC64L3U ATUC64L4U
AT32UC3L0128ZAUR, AT32UC3L0128 ZAUR
