Datasheet Microchip ATSAM4N16CA-AUR — Даташит
| Производитель | Microchip |
| Серия | ATSAM4N16C |
| Модель | ATSAM4N16CA-AUR |
Микроконтроллер Microchip ATSAMN16C на базе ARM® Cortex®-M4 работает на частоте 100 МГц и имеет 1 МБ флэш-памяти и 80 КБ SRAM.
Купить ATSAM4N16CA-AUR на РадиоЛоцман.Цены — от 197 до 1 067 ₽31 предложений от 17 поставщиков IC MCU 32BIT 1MB FLASH 100LQFP. ARM® Cortex®-M4 SAM4N Microcontroller IC 32-Bit 100MHz 1MB (1M x 8) FLASH 100-LQFP (14x14). Embedded... | |||
| ATSAM4N16CA-AUR Microchip | 197 ₽ | ||
| ATSAM4N16CA-AUR Atmel | 318 ₽ | ||
| ATSAM4N16CA-AUR | 455 ₽ | ||
| ATSAM4N16CA-AUR Microchip | по запросу | ||
| Корпус | LQFP |
| Количество выводов | 100 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | Cortex-M4 |
| CRC/Scan | No |
| Cap. Touch Channels | 32 |
| High Voltage Capable | No |
| I2C | 3 |
| Internal Oscillator | 4,8,12Mhz,32Khz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 4 including complementary outputs |
| Max 16 Bit Digital Timers | 6 |
| Max 8 Bit Digital Timers | 6 |
| Max A/D Resolution | 10 bits |
| Max D/A Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 100 |
| Number of D/A Converters | 1 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 1.62 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 100 |
| Размер памяти программ | 1024 Kbytes |
| RAM | 81920 bytes |
| SPIв„ў | 4 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 16 |
| UART | 7 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
ATSAM4N16B ATSAM4N8A ATSAM4N8B ATSAM4N8C
Серия: ATSAM4N16C (6)
- ATSAM4N16CA-AU ATSAM4N16CA-AUR ATSAM4N16CA-CFU ATSAM4N16CA-CFUR ATSAM4N16CA-CU ATSAM4N16CA-CUR
ATSAM4N16CAAUR, ATSAM4N16CA AUR
