Datasheet Microchip ATSAM4S4AA-AU — Даташит
Производитель | Microchip |
Серия | ATSAM4S4A |
Модель | ATSAM4S4AA-AU |
Микроконтроллер SAM4S4A на базе ARM® от Microchip построен на высокопроизводительном 32-битном ядре Cortex®-M4.
![]() 35 предложений от 18 поставщиков Микросхема Микроконтроллер 32, MCU 32Bit SAM4S ARM Cortex M4 RISC 256KB Flash 1.2V/3.3V 48Pin LQFP Tray | |||
ATSAM4S4AA-AU Microchip | от 311 ₽ | ||
ATSAM4S4AA-AU Microchip | 327 ₽ | ||
ATSAM4S4AA-AU Microchip | от 737 ₽ | ||
ATSAM4S4AA-AU Atmel | по запросу |
Корпус | LQFP |
Количество выводов | 48 |
# of Comparators | 1 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4 |
CRC/Scan | No |
Cap. Touch Channels | 17 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 4,8,12Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 6 |
Max 8 Bit Digital Timers | 6 |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 120 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 48 |
Размер памяти программ | 256 Kbytes |
RAM | 65536 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 8 |
UART | 3 |
Zero Cross detect | No |
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4B ATSAM4S4C ATSAM4S8B ATSAM4S8C ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD16C ATSAM4SD32B ATSAM4SD32C
Серия: ATSAM4S4A (6)
- ATSAM4S4AA-AU ATSAM4S4AA-MU ATSAM4S4AB-AN ATSAM4S4AB-ANR ATSAM4S4AB-MN ATSAM4S4AB-MNR
ATSAM4S4AAAU, ATSAM4S4AA AU
