Datasheet Microchip ATSAM4S4CA-CU — Даташит
СерияATSAM4S4C
МодельATSAM4S4CA-CU
Микроконтроллер SAM4S4C на базе ARM® от Microchip построен на высокопроизводительном 32-битном ядре Cortex®-M4.
SAM4S Series Datasheet
PDF, 5.7 Мб, Версия: 06-01-2015
IC MCU 32BIT 256KB FLASH 100BGA. ARM® Cortex®-M4 SAM4S Microcontroller IC 32-Bit 120MHz 256KB (256K x 8) FLASH 100-TFBGA (9x9). Embedded...
ATSAM4S4CA-CU
Atmel
81 ₽
ATSAM4S4CA-CU
328 ₽
ATSAM4S4CA-CU
Atmel
423 ₽
Hi-Tech Circuit Group
ATSAM4S4CA-CU
КорпусTFBGA
Количество выводов100
# of Comparators1
ADCC with ComputationNo
Angular TimerNo
Архитектура32
CPUCortex-M4
CRC/ScanNo
Cap. Touch Channels32
High Voltage CapableNo
I2C2
Internal Oscillator4,8,12Mhz,32Khz
Math AcceleratorNo
Max # PWM outputs8 including complementary outputs
Max 16 Bit Digital Timers6
Max 8 Bit Digital Timers6
Max A/D Resolution12 bits
Max D/A Resolution12 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz120
Number of D/A Converters1
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)1.62
Peripheral Pin SelectYes PPS
Pin count100
Размер памяти программ256 Kbytes
RAM65536 bytes
SPIв„ў3
Temp. Range Max.85
Temp. Range Min.-40
Total # of A/D channels15
UART4
Zero Cross detectNo
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4A ATSAM4S4B ATSAM4S8B ATSAM4S8C ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD16C ATSAM4SD32B ATSAM4SD32C
ATSAM4S4CACU, ATSAM4S4CA CU
На английском языке: Datasheet Microchip ATSAM4S4CA-CU
