Datasheet Microchip ATSAM4S8CB-CFNR — Даташит
Производитель | Microchip |
Серия | ATSAM4S8C |
Модель | ATSAM4S8CB-CFNR |
Микроконтроллер SAM4S8 на базе ARM® построен на высокопроизводительном 32-битном ядре Cortex®-M4 на базе ARM®.
![]() 6 предложений от 6 поставщиков , MCU 32Bit ARM Cortex M4 RISC 512KB Flash 1.2V/3.3V 100Pin VFBGA T/R | |||
ATSAM4S8CB-CFNR Microchip | 175 ₽ | ||
ATSAM4S8CB-CFNR | 409 ₽ | ||
ATSAM4S8CB-CFNR Microchip | по запросу | ||
Корпус | VFBGA |
Количество выводов | 100 |
# of Comparators | 1 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4 |
CRC/Scan | No |
Cap. Touch Channels | 32 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 4,8,12Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 6 |
Max 8 Bit Digital Timers | 6 |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 120 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 100 |
Размер памяти программ | 512 Kbytes |
RAM | 131072 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 15 |
UART | 4 |
Zero Cross detect | No |
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4A ATSAM4S4B ATSAM4S4C ATSAM4S8B ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD16C ATSAM4SD32B ATSAM4SD32C
Серия: ATSAM4S8C (16)
ATSAM4S8CBCFNR, ATSAM4S8CB CFNR
