Datasheet Microchip ATSAM4SD16CB-ANR — Даташит
| Производитель | Microchip |
| Серия | ATSAM4SD16C |
| Модель | ATSAM4SD16CB-ANR |
Микроконтроллер SAM4SD16 на базе ARM® от Microchip построен на высокопроизводительном 32-битном ядре Cortex®-M4.
Купить ATSAM4SD16CB-ANR на РадиоЛоцман.Цены — от 198 до 1 409 ₽17 предложений от 9 поставщиков IC MCU 32BIT 1MB FLASH 100LQFP. ARM® Cortex®-M4 SAM4S Microcontroller IC 32-Bit 120MHz 1MB (1M x 8) FLASH 100-LQFP (14x14). Embedded... | |||
| ATSAM4SD16CB-ANR Microchip | 554 ₽ | ||
| ATSAM4SD16CB-ANR | 620 ₽ | ||
| ATSAM4SD16CB-ANR Microchip | 730 ₽ | ||
| ATSAM4SD16CB-ANR Microchip | от 1 309 ₽ | ||
| Корпус | LQFP |
| Количество выводов | 100 |
| # of Comparators | 1 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | Cortex-M4 |
| CRC/Scan | No |
| Cap. Touch Channels | 32 |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 4,8,12Mhz,32Khz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 4 including complementary outputs |
| Max 16 Bit Digital Timers | 6 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 12 bits |
| Max. CPU Speed MHz | 120 |
| Number of D/A Converters | 1 |
| Number of USB Modules | 1 |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 1.62 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 100 |
| Размер памяти программ | 1024 Kbytes |
| RAM | 163840 bytes |
| SPIв„ў | 3 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 15 |
| UART | 4 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4A ATSAM4S4B ATSAM4S4C ATSAM4S8B ATSAM4S8C ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD32B ATSAM4SD32C
Серия: ATSAM4SD16C (12)
ATSAM4SD16CBANR, ATSAM4SD16CB ANR
