Datasheet Microchip ATSAM4SD16CB-CNR — Даташит
Производитель | Microchip |
Серия | ATSAM4SD16C |
Модель | ATSAM4SD16CB-CNR |
Микроконтроллер SAM4SD16 на базе ARM® от Microchip построен на высокопроизводительном 32-битном ядре Cortex®-M4.
![]() 7 предложений от 7 поставщиков , MCU 32Bit ARM Cortex M4 RISC 1024KB Flash 1.2V/3.3V 100Pin TFBGA T/R | |||
ATSAM4SD16CB-CNR Microchip | 219 ₽ | ||
ATSAM4SD16CB-CNR Microchip | 242 ₽ | ||
ATSAM4SD16CB-CNR | 565 ₽ | ||
ATSAM4SD16CB-CNR Microchip | по запросу |
Корпус | TFBGA |
Количество выводов | 100 |
# of Comparators | 1 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4 |
CRC/Scan | No |
Cap. Touch Channels | 32 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 4,8,12Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 4 including complementary outputs |
Max 16 Bit Digital Timers | 6 |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 120 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 100 |
Размер памяти программ | 1024 Kbytes |
RAM | 163840 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 15 |
UART | 4 |
Zero Cross detect | No |
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4A ATSAM4S4B ATSAM4S4C ATSAM4S8B ATSAM4S8C ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD32B ATSAM4SD32C
Серия: ATSAM4SD16C (12)
ATSAM4SD16CBCNR, ATSAM4SD16CB CNR
