Datasheet Microchip ATSAM4SD32BB-MNR — Даташит
| Производитель | Microchip |
| Серия | ATSAM4SD32B |
| Модель | ATSAM4SD32BB-MNR |
Микроконтроллер SAM4SD32 на базе ARM® от Microchip построен на высокопроизводительном 32-битном ядре Cortex®-M4.
Купить ATSAM4SD32BB-MNR на РадиоЛоцман.Цены — от 280 до 1 810 ₽18 предложений от 10 поставщиков IC MCU 32BIT 2MB FLASH 64QFN. ARM® Cortex®-M4 SAM4S Microcontroller IC 32-Bit 120MHz 2MB (2M x 8) FLASH 64-QFN (9x9). Embedded... | |||
| ATSAM4SD32BB-MNR Microchip | 280 ₽ | ||
| ATSAM4SD32BB-MNR Microchip | 627 ₽ | ||
| ATSAM4SD32BB-MNR Microchip | 937 ₽ | ||
| ATSAM4SD32BB-MNR Microchip | от 1 810 ₽ | ||
| Корпус | VQFN |
| Количество выводов | 64 |
| # of Comparators | 1 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | Cortex-M4 |
| CRC/Scan | No |
| Cap. Touch Channels | 23 |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 4,8,12Mhz,32Khz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 4 including complementary outputs |
| Max 16 Bit Digital Timers | 6 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 12 bits |
| Max. CPU Speed MHz | 120 |
| Number of D/A Converters | 1 |
| Number of USB Modules | 1 |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 1.62 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 64 |
| Размер памяти программ | 2048 Kbytes |
| RAM | 163840 bytes |
| SPIв„ў | 3 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 10 |
| UART | 4 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4A ATSAM4S4B ATSAM4S4C ATSAM4S8B ATSAM4S8C ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD16C ATSAM4SD32C
Серия: ATSAM4SD32B (10)
ATSAM4SD32BBMNR, ATSAM4SD32BB MNR
