Datasheet Microchip ATSAMC21G17A-MUT — Даташит
Производитель | Microchip |
Серия | ATSAMC21G17A |
Модель | ATSAMC21G17A-MUT |
Серия устройств Microchip SAM C с напряжением 5 В Cortex M0+ предназначена для промышленного и коммерческого применения в шумных условиях.
![]() 11 предложений от 8 поставщиков , ARM Microcontrollers - MCU Cortex-M0+, 128KB FLASH,16KB SRAM - 48QFN,85C TEMP, GREEN, 5V, 48MHz, T&R | |||
ATSAMC21G17A-MUT Atmel | 148 ₽ | ||
ATSAMC21G17A-MUT Microchip | от 759 ₽ | ||
ATSAMC21G17A-MUT Microchip | по запросу | ||
Корпус | VQFN |
Количество выводов | 48 |
# of Comparators | 4 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Cap. Touch Channels | 120 |
Configurable Logic Cell Modules | 4 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 6 |
Internal Oscillator | 32khz, 32Khz ULP, 48Mhz |
Math Accelerator | No |
Max # PWM outputs | 24 including complementary outputs |
Max 8 Bit Digital Timers | 5 |
Max D/A Resolution | 10 bits |
Max PWM Resolution | 32 bits |
Max. CPU Speed MHz | 48 |
Operation Voltage Max.(V) | 5.5 |
Operation Voltage Min.(V) | 2.7 |
Pin count | 48 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 6 |
Signal Measurement Timer | 1 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 12 |
UART | 6 |
Zero Cross detect | No |
ATSAMC20E15A ATSAMC20E16A ATSAMC20E17A ATSAMC20E18A ATSAMC20G15A ATSAMC20G16A ATSAMC20G17A ATSAMC20G18A ATSAMC20J15A ATSAMC20J16A ATSAMC20J17A ATSAMC20J18A ATSAMC20N17A ATSAMC20N18A ATSAMC21E17A ATSAMC21E18A ATSAMC21G18A ATSAMC21J17A ATSAMC21J18A ATSAMC21N17A ATSAMC21N18A
Серия: ATSAMC21G17A (4)
- ATSAMC21G17A-ANT ATSAMC21G17A-AUT ATSAMC21G17A-MNT ATSAMC21G17A-MUT
ATSAMC21G17AMUT, ATSAMC21G17A MUT
