Datasheet Microchip ATSAMD20G16B-AU — Даташит
| Производитель | Microchip |
| Серия | ATSAMD20G16 |
| Модель | ATSAMD20G16B-AU |
Маломощный, высокопроизводительный флэш-микроконтроллер Microchip на базе ARM® Cortex®-M0+, ATSAMD20G16 идеально подходит для широкого спектра домашней автоматизации, бытовых, измерительных и промышленных приложений.
 Купить ATSAMD20G16B-AU на РадиоЛоцман.Цены — от 57 до 432 ₽21 предложений от 13 поставщиков IC MCU 32BIT 64KB FLASH 48TQFP. ARM® Cortex®-M0+ SAM D20G Microcontroller IC 32-Bit 48MHz 64KB (64K x 8) FLASH 48-TQFP (7x7)....  | |||
| ATSAMD20G16B-AU Microchip  | 141 ₽ | ||
| ATSAMD20G16B-AU Microchip  | от 178 ₽ | ||
| ATSAMD20G16B-AU Microchip  | 432 ₽ | ||
| ATSAMD20G16B-AU Microchip  | по запросу | ||
| Корпус | TQFP |
| Количество выводов | 48 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | Cortex-M0+ |
| CRC/Scan | Yes |
| Cap. Touch Channels | 120 |
| High Voltage Capable | No |
| I2C | 6 |
| Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 12 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max 8 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 48 |
| Number of D/A Converters | 1 |
| Operation Voltage Max.(V) | 3.63 |
| Operation Voltage Min.(V) | 1.62 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 48 |
| Размер памяти программ | 64 Kbytes |
| RAM | 8192 bytes |
| SPIв„ў | 6 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 14 |
| UART | 6 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
ATSAMD20E14 ATSAMD20E15 ATSAMD20E16 ATSAMD20E17 ATSAMD20E18 ATSAMD20G14 ATSAMD20G15 ATSAMD20G17 ATSAMD20G18 ATSAMD20J14 ATSAMD20J15 ATSAMD20J16 ATSAMD20J17 ATSAMD20J18
Серия: ATSAMD20G16 (16)
ATSAMD20G16BAU, ATSAMD20G16B AU
