Datasheet Microchip ATUC256L4U-AUR — Даташит
СерияATUC256L4U
МодельATUC256L4U-AUR
The high-performance 32-bit AVRВ® UC3 RISC microcontroller is designed for cost-sensitive embedded applications that require low power consumption, high code density, and high performance.
Atmel AVR 32-bit Architecture Manual - Complete Datasheet
PDF, 5.1 Мб, Версия: 04-01-2011
ATUCL3U/L4U Series - Complete Datasheet
PDF, 12.2 Мб, Версия: 06-01-2013
ATUCL3U/L4U Series - Summary Datasheet
PDF, 439 Кб, Версия: 06-01-2013
AVR32UC Technical Reference Datasheet
PDF, 1.1 Мб, Версия: 03-01-2010
15 предложений от 15 поставщиков
ATUC256L4U-AUR
434 ₽
ATUC256L4U-AUR
580 ₽
ATUC256L4U-AUR
Atmel
731 ₽
ATUC256L4U-AUR
Atmel
КорпусTQFP
Количество выводов48
# of Comparators8
ADCC with ComputationNo
Angular TimerNo
Архитектура32
CPU32-bit AVR
CRC/ScanNo
Cap. Touch Channels17
Configurable Logic Cell Modules1 CLC
High Voltage CapableNo
I2C2
Internal Oscillator120Mhz,115Khz,32Khz
Math AcceleratorNo
Max # PWM outputs35 including complementary outputs
Max 16 Bit Digital Timers6
Max A/D Resolution12 bits
Max. CPU Speed MHz50
Number of D/A Converters1
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)1.62
Peripheral Pin SelectYes PPS
Pin count48
Размер памяти программ256 Kbytes
RAM16384 bytes
SPIв„ў1
Temp. Range Max.85
Temp. Range Min.-40
Total # of A/D channels8
UART4
Zero Cross detectNo
AT32UC3A0128 AT32UC3A0256 AT32UC3A0512 AT32UC3A1128 AT32UC3A1256 AT32UC3A1512 AT32UC3A3128 AT32UC3A3128S AT32UC3A3256 AT32UC3A3256S AT32UC3A364 AT32UC3A364S AT32UC3A4128 AT32UC3A4128S AT32UC3A4256 AT32UC3A4256S AT32UC3A464 AT32UC3A464S AT32UC3B0128 AT32UC3B0256 AT32UC3B0512 AT32UC3B064 AT32UC3B1128 AT32UC3B1256 AT32UC3B1512 AT32UC3B164 AT32UC3C0128C AT32UC3C0256C AT32UC3C0512C AT32UC3C0512C-AUTOMOTIVE AT32UC3C064C AT32UC3C1128C AT32UC3C1256C AT32UC3C1512C AT32UC3C1512C-AUTOMOTIVE AT32UC3C164C AT32UC3C2128C AT32UC3C2256C AT32UC3C2512C AT32UC3C2512C-AUTOMOTIVE AT32UC3C264C AT32UC3L0128 AT32UC3L0256 ATUC128D3 ATUC128L3U ATUC128L4U ATUC256L3U ATUC64D3 ATUC64D4 ATUC64L3U ATUC64L4U
ATUC256L4UAUR, ATUC256L4U AUR
На английском языке: Datasheet Microchip ATUC256L4U-AUR
