Datasheet Microchip ATUC256L4U-ZAUT — Даташит
| Производитель | Microchip |
| Серия | ATUC256L4U |
| Модель | ATUC256L4U-ZAUT |
The high-performance 32-bit AVRВ® UC3 RISC microcontroller is designed for cost-sensitive embedded applications that require low power consumption, high code density, and high performance.
|  Купить ATUC256L4U-ZAUT на РадиоЛоцман.Цены — от 417 до 2 100 ₽ 18 предложений от 18 поставщиков IC MCU 32BIT 256KB FLASH 48QFN / AVR series Microcontroller IC 32-Bit Single-Core 50MHz 256KB (256K x 8) FLASH 48-QFN (7x7)... | |||
| ATUC256L4U-ZAUT Microchip | 666 ₽ | ||
| ATUC256L4U-ZAUT Atmel | 1 833 ₽ | ||
| ATUC256L4U-ZAUT Microchip | по запросу | ||
| ATUC256L4U-ZAUT Atmel | по запросу | ||
| Корпус | VQFN |
| Количество выводов | 48 |
| # of Comparators | 8 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | 32-bit AVR |
| CRC/Scan | No |
| Cap. Touch Channels | 17 |
| Configurable Logic Cell Modules | 1 CLC |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 120Mhz,115Khz,32Khz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 35 including complementary outputs |
| Max 16 Bit Digital Timers | 6 |
| Max A/D Resolution | 12 bits |
| Max. CPU Speed MHz | 50 |
| Number of D/A Converters | 1 |
| Number of USB Modules | 1 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 1.62 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 48 |
| Размер памяти программ | 256 Kbytes |
| RAM | 16384 bytes |
| SPIв„ў | 1 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 8 |
| UART | 4 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
AT32UC3A0128 AT32UC3A0256 AT32UC3A0512 AT32UC3A1128 AT32UC3A1256 AT32UC3A1512 AT32UC3A3128 AT32UC3A3128S AT32UC3A3256 AT32UC3A3256S AT32UC3A364 AT32UC3A364S AT32UC3A4128 AT32UC3A4128S AT32UC3A4256 AT32UC3A4256S AT32UC3A464 AT32UC3A464S AT32UC3B0128 AT32UC3B0256 AT32UC3B0512 AT32UC3B064 AT32UC3B1128 AT32UC3B1256 AT32UC3B1512 AT32UC3B164 AT32UC3C0128C AT32UC3C0256C AT32UC3C0512C AT32UC3C0512C-AUTOMOTIVE AT32UC3C064C AT32UC3C1128C AT32UC3C1256C AT32UC3C1512C AT32UC3C1512C-AUTOMOTIVE AT32UC3C164C AT32UC3C2128C AT32UC3C2256C AT32UC3C2512C AT32UC3C2512C-AUTOMOTIVE AT32UC3C264C AT32UC3L0128 AT32UC3L0256 ATUC128D3 ATUC128L3U ATUC128L4U ATUC256L3U ATUC64D3 ATUC64D4 ATUC64L3U ATUC64L4U
- ATUC256L4U-AUR ATUC256L4U-AUT ATUC256L4U-D3HR ATUC256L4U-D3HT ATUC256L4U-ZAUR ATUC256L4U-ZAUT
ATUC256L4UZAUT, ATUC256L4U ZAUT
