Datasheet Microchip DSPIC33EP128GS702T-E/MM — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EP128GS702 |
| Модель | DSPIC33EP128GS702T-E/MM |
dsPIC33EPXXGS70X/80X — это контроллер цифрового сигнала с импульсным источником питания и цифровым преобразованием мощности.
, 128KB flash 70MIPS DSC optimized for digital power applications | |||
| DSPIC33EP128GS702T-E/MM Microchip | 263 ₽ | ||
| Корпус | QFN-S |
| Количество выводов | 28 |
| # of Comparators | 4 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| Configurable Logic Cell Modules | 4 CLC |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 7.37 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 10 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 12 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 70 |
| Number of D/A Converters | 4 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 128 Kbytes |
| RAM | 8192 bytes |
| SPIв„ў | 3 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 11 |
| UART | 2 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
dsPIC33EP128GS704 dsPIC33EP128GS705 dsPIC33EP128GS706 dsPIC33EP128GS708 dsPIC33EP128GS804 dsPIC33EP128GS805 dsPIC33EP128GS806 dsPIC33EP128GS808 dsPIC33EP64GS708 dsPIC33EP64GS804 dsPIC33EP64GS805 dsPIC33EP64GS806 dsPIC33EP64GS808
Серия: dsPIC33EP128GS702 (12)
DSPIC33EP128GS702TE/MM, DSPIC33EP128GS702T E/MM
Купить DSPIC33EP128GS702T-E/MM на РадиоЛоцман.Цены
