Datasheet Microchip dsPIC33EP16GS202 — Даташит
СерияdsPIC33EP16GS202
dsPIC33EPXXGS202 — это контроллер цифрового сигнала с импульсным источником питания и цифровым преобразованием мощности.
dsPIC33EPXXGS202 Family Data Sheet
PDF, 2.9 Мб, Версия: 05-25-2016
28 предложений от 15 поставщиков
Микросхема Микроконтроллер, 16KB flash, 70MIPS, DSC optimized for digital power applications, 28 SOIC 0.3in TUBE
DSPIC33EP16GS202-I/SS
от 79 ₽
DSPIC33EP16GS202-E/SO
95 ₽
DSPIC33EP16GS202-I/M6
267 ₽
Hi-Tech Circuit Group
DSPIC33EP16GS202-E/M6DSPIC33EP16GS202-E/MMDSPIC33EP16GS202-E/MXDSPIC33EP16GS202-E/SODSPIC33EP16GS202-E/SSDSPIC33EP16GS202-E/SSVAODSPIC33EP16GS202-I/M6DSPIC33EP16GS202-I/MMDSPIC33EP16GS202-I/MXDSPIC33EP16GS202-I/SODSPIC33EP16GS202-I/SSDSPIC33EP16GS202T-E/M6DSPIC33EP16GS202T-E/MMDSPIC33EP16GS202T-E/MXDSPIC33EP16GS202T-E/SODSPIC33EP16GS202T-E/SSDSPIC33EP16GS202T-E/SSVAODSPIC33EP16GS202T-I/M6DSPIC33EP16GS202T-I/MMDSPIC33EP16GS202T-I/MXDSPIC33EP16GS202T-I/SODSPIC33EP16GS202T-I/SS
Статус продуктаSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples AvailableSamples Available
N12345678910111213141516171819202122
КорпусUQFNQFN-SUQFNSOICSSOPSSOPUQFNQFN-SUQFNSOICSSOPUQFNQFN-SUQFNSOICSSOPSSOPUQFNQFN-SUQFNSOICSSOP
Количество выводов28282828282828282828282828282828282828282828
Parameters / ModelsDSPIC33EP16GS202-E/M6DSPIC33EP16GS202-E/MMDSPIC33EP16GS202-E/MXDSPIC33EP16GS202-E/SODSPIC33EP16GS202-E/SSDSPIC33EP16GS202-E/SSVAODSPIC33EP16GS202-I/M6DSPIC33EP16GS202-I/MMDSPIC33EP16GS202-I/MXDSPIC33EP16GS202-I/SODSPIC33EP16GS202-I/SSDSPIC33EP16GS202T-E/M6DSPIC33EP16GS202T-E/MMDSPIC33EP16GS202T-E/MXDSPIC33EP16GS202T-E/SODSPIC33EP16GS202T-E/SSDSPIC33EP16GS202T-E/SSVAODSPIC33EP16GS202T-I/M6DSPIC33EP16GS202T-I/MMDSPIC33EP16GS202T-I/MXDSPIC33EP16GS202T-I/SODSPIC33EP16GS202T-I/SS
# of Comparators2222222222222222222222
ADCC with ComputationNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Angular TimerNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Архитектура16161616161616161616161616161616161616161616
CPU16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC16-bit dsPIC DSC
CRC/ScanNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
EEPROM / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF0 / HEF
High Voltage CapableNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
I2C1111111111111111111111
Internal Oscillator7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz7.37 MHz, 32 kHz
Internal Voltage Reference, BandgapYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Math AcceleratorNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Max # PWM outputs, including complementary outputs6666666666666666666666
Max 16 Bit Digital Timers3333333333333333333333
Max A/D Resolution, bits12121212121212121212121212121212121212121212
Max D/A Resolution, bits12121212121212121212121212121212121212121212
Max PWM Resolution, bits16161616161616161616161616161616161616161616
Max. CPU Speed MHz70707070707070707070707070707070707070707070
Number of D/A Converters2222222222222222222222
Рабочий диапазон температур, °Cот -40 до +125от -40 до +125от -40 до +125от -40 до +125от -40 до +125от -40 до +85от -40 до +85от -40 до +85от -40 до +85от -40 до +85от -40 до +125от -40 до +125от -40 до +125от -40 до +125от -40 до +125от -40 до +85от -40 до +85от -40 до +85от -40 до +85от -40 до +85
Operation Voltage Max.(V)3.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.63.6
Operation Voltage Min.(V)3333333333333333333333
Peripheral Pin Select, PPSYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes
Pin count28282828282828282828282828282828282828282828
Размер памяти программ, Kbytes16161616161616161616161616161616161616161616
RAM, bytes2048204820482048204820482048204820482048204820482048204820482048204820482048204820482048
SPIв„ў1111111111111111111111
Temp. Range Max.125125125125125125125125125125125125125125125125125125125125125125
Temp. Range Min.-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40-40
Total # of A/D channels12121212121212121212121212121212121212121212
UART1111111111111111111111
Windowed Watchdog Timer, WWDTNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
Zero Cross detectNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNoNo
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
dsPIC33EP32GS202
На английском языке: Datasheet Microchip dsPIC33EP16GS202
