Datasheet Microchip DSPIC33EP32GS202-I/SO — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EP32GS202 |
| Модель | DSPIC33EP32GS202-I/SO |
dsPIC33EPXXGS202 — это контроллер цифрового сигнала с импульсным источником питания и цифровым преобразованием мощности.
Купить DSPIC33EP32GS202-I/SO на РадиоЛоцман.Цены — от 29 до 1 049 ₽29 предложений от 17 поставщиков IC MCU 16BIT 32KB FLASH 28SOIC. dsPIC dsPICTM 33EP Microcontroller IC 16-Bit 70 MIPs 32KB (32K x 8) FLASH 28-SOIC.... | |||
| DSPIC33EP32GS202-I/SO Microchip | 29 ₽ | ||
| DSPIC33EP32GS202-I/SO Microchip | 237 ₽ | ||
| DSPIC33EP32GS202-I/SO Microchip | от 653 ₽ | ||
| DSPIC33EP32GS202-I/SO Microchip | от 708 ₽ | ||
| Корпус | SOIC |
| Количество выводов | 28 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 6 including complementary outputs |
| Max 16 Bit Digital Timers | 3 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 12 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 70 |
| Number of D/A Converters | 2 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 32 Kbytes |
| RAM | 2048 bytes |
| SPIв„ў | 1 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 12 |
| UART | 1 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
Серия: dsPIC33EP32GS202 (20)
- DSPIC33EP32GS202-E/M6 DSPIC33EP32GS202-E/MM DSPIC33EP32GS202-E/MX DSPIC33EP32GS202-E/SO DSPIC33EP32GS202-E/SS DSPIC33EP32GS202-I/M6 DSPIC33EP32GS202-I/MM DSPIC33EP32GS202-I/MX DSPIC33EP32GS202-I/SO DSPIC33EP32GS202-I/SS DSPIC33EP32GS202T-E/M6 DSPIC33EP32GS202T-E/MM DSPIC33EP32GS202T-E/MX DSPIC33EP32GS202T-E/SO DSPIC33EP32GS202T-E/SS DSPIC33EP32GS202T-I/M6 DSPIC33EP32GS202T-I/MM DSPIC33EP32GS202T-I/MX DSPIC33EP32GS202T-I/SO DSPIC33EP32GS202T-I/SS
DSPIC33EP32GS202I/SO, DSPIC33EP32GS202 I/SO
