Datasheet Microchip DSPIC33EP32GS504-I/ML — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EP32GS504 |
| Модель | DSPIC33EP32GS504-I/ML |
dsPIC33EPXXGS50X — это контроллер цифрового сигнала с импульсным источником питания и цифровым преобразованием мощности.
Купить DSPIC33EP32GS504-I/ML на РадиоЛоцман.Цены — от 12 до 847 ₽20 предложений от 14 поставщиков IC MCU 16BIT 32KB FLASH 44QFN. dsPIC dsPICTM 33EP Microcontroller IC 16-Bit 70 MIPs 32KB (32K x 8) FLASH 44-QFN... | |||
| DSPIC33EP32GS504-I/ML Microchip | 245 ₽ | ||
| DSPIC33EP32GS504-I/ML Microchip | 277 ₽ | ||
| DSPIC33EP32GS504-I/ML Microchip | 847 ₽ | ||
| DSPIC33EP32GS504-I/ML Microchip | по запросу | ||
| Корпус | QFN |
| Количество выводов | 44 |
| # of Comparators | 4 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 7.37 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 10 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 12 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 70 |
| Number of D/A Converters | 4 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 44 |
| Размер памяти программ | 32 Kbytes |
| RAM | 4096 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 19 |
| UART | 2 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
dsPIC33EP16GS502 dsPIC33EP16GS504 dsPIC33EP16GS505 dsPIC33EP16GS506 dsPIC33EP32GS502 dsPIC33EP32GS505 dsPIC33EP32GS506 dsPIC33EP64GS502 dsPIC33EP64GS504 dsPIC33EP64GS505 dsPIC33EP64GS506
Серия: dsPIC33EP32GS504 (8)
DSPIC33EP32GS504I/ML, DSPIC33EP32GS504 I/ML
