Datasheet Microchip dsPIC33EP64GS505 — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EP64GS505 |
dsPIC33EPXXGS50X — это контроллер цифрового сигнала с импульсным источником питания и цифровым преобразованием мощности.
|  Купить dsPIC33EP64GS505 на РадиоЛоцман.Цены — от 131 до 1 043 ₽ 12 предложений от 10 поставщиков IC MCU 16BIT 64KB FLASH 48TQFP. dsPIC dsPICTM 33EP Microcontroller IC 16-Bit 70 MIPs 64KB (64K x 8) FLASH 48-TQFP-EP... | |||
| DSPIC33EP64GS505-I/PT Microchip | 131 ₽ | ||
| DSPIC33EP64GS505-I/PT Microchip | 348 ₽ | ||
| DSPIC33EP64GS505-I/PT Microchip | от 901 ₽ | ||
| DSPIC33EP64GS505-I/PT Microchip | 1 043 ₽ | ||
| DSPIC33EP64GS505-E/PT | DSPIC33EP64GS505-I/PT | DSPIC33EP64GS505T-E/PT | DSPIC33EP64GS505T-I/PT | |
| Статус продукта | Samples Available | Samples Available | Samples Available | Samples Available |
| N | 1 | 2 | 3 | 4 |
| Корпус | TQFP | TQFP | TQFP | TQFP |
| Количество выводов | 48 | 48 | 48 | 48 |
| Parameters / Models | DSPIC33EP64GS505-E/PT | DSPIC33EP64GS505-I/PT | DSPIC33EP64GS505T-E/PT | DSPIC33EP64GS505T-I/PT |
| # of Comparators | 4 | 4 | 4 | 4 |
| ADCC with Computation | No | No | No | No |
| Angular Timer | No | No | No | No |
| Архитектура | 16 | 16 | 16 | 16 |
| CPU | 16-bit dsPIC DSC | 16-bit dsPIC DSC | 16-bit dsPIC DSC | 16-bit dsPIC DSC |
| CRC/Scan | No | No | No | No |
| EEPROM / HEF | 0 / HEF | 0 / HEF | 0 / HEF | 0 / HEF |
| High Voltage Capable | No | No | No | No |
| I2C | 2 | 2 | 2 | 2 |
| Internal Oscillator | 7.37 MHz, 32 kHz | 7.37 MHz, 32 kHz | 7.37 MHz, 32 kHz | 7.37 MHz, 32 kHz |
| Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes |
| Math Accelerator | No | No | No | No |
| Max # PWM outputs, including complementary outputs | 10 | 10 | 10 | 10 |
| Max 16 Bit Digital Timers | 5 | 5 | 5 | 5 |
| Max A/D Resolution, bits | 12 | 12 | 12 | 12 |
| Max D/A Resolution, bits | 12 | 12 | 12 | 12 |
| Max PWM Resolution, bits | 16 | 16 | 16 | 16 |
| Max. CPU Speed MHz | 70 | 70 | 70 | 70 |
| Number of D/A Converters | 4 | 4 | 4 | 4 |
| Рабочий диапазон температур, °C | от -40 до +125 | от -40 до +85 | от -40 до +125 | от -40 до +85 |
| Operation Voltage Max.(V) | 3.6 | 3.6 | 3.6 | 3.6 |
| Operation Voltage Min.(V) | 3 | 3 | 3 | 3 |
| Peripheral Pin Select, PPS | Yes | Yes | Yes | Yes |
| Pin count | 48 | 48 | 48 | 48 |
| Размер памяти программ, Kbytes | 64 | 64 | 64 | 64 |
| RAM, bytes | 8192 | 8192 | 8192 | 8192 |
| SPIв„ў | 2 | 2 | 2 | 2 |
| Temp. Range Max. | 125 | 125 | 125 | 125 |
| Temp. Range Min. | -40 | -40 | -40 | -40 |
| Total # of A/D channels | 19 | 19 | 19 | 19 |
| UART | 2 | 2 | 2 | 2 |
| Windowed Watchdog Timer, WWDT | No | No | No | No |
| Zero Cross detect | No | No | No | No |
| RoHS | Совместим | Совместим | Совместим | Совместим |
dsPIC33EP16GS502 dsPIC33EP16GS504 dsPIC33EP16GS505 dsPIC33EP16GS506 dsPIC33EP32GS502 dsPIC33EP32GS504 dsPIC33EP32GS505 dsPIC33EP32GS506 dsPIC33EP64GS502 dsPIC33EP64GS504 dsPIC33EP64GS506
Серия: dsPIC33EP64GS505 (4)
