Datasheet Microchip PIC16F1454-E/ML — Даташит
| Производитель | Microchip |
| Серия | PIC16F1454 |
| Модель | PIC16F1454-E/ML |
Купить PIC16F1454-E/ML на РадиоЛоцман.Цены — от 77 до 145 ₽11 предложений от 11 поставщиков IC MCU 8BIT 14KB FLASH 16QFN. PIC PIC® XLPTM 16F Microcontroller IC 8-Bit 48MHz 14KB (8K x 14) FLASH 16-QFN... | |||
| PIC16F1454-E/ML Microchip | 77 ₽ | ||
| PIC16F1454-E/ML | 111 ₽ | ||
| PIC16F1454-E/ML Microchip | 113 ₽ | ||
| PIC16F1454-E/ML Microchip | по запросу | ||
| Корпус | QFN |
| ADC with Computation | No |
| Angular Timer | No |
| Архитектура | 8 |
| CPU Type | 8-bit PIC MCU |
| CRC | No |
| Class B Hardware | No |
| Emulated EEPROM in Flash | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 16 MHz, 32 kHz |
| Internal Voltage Reference | No Bandgap |
| Lead Count | 16 |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 1 |
| Max 8-Bit Digital Timers | 1 |
| Max CPU Speed | 48 МГц |
| Max PWM outputs | 2 including complementary |
| Number of USB Modules | 1 |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| Package Width | 4x4x0.9mm |
| Peripheral Pin Select / Pin Muxing | No |
| Pin count | 14 |
| Размер памяти программ | 14 KB |
| SPI | 1 |
| SRAM | 1024 Bytes |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 1 |
| Zero Cross detect | No |
Серия: PIC16F1454 (30)
- PIC16F1454-E/JQ PIC16F1454-E/ML PIC16F1454-E/P PIC16F1454-E/SL PIC16F1454-E/ST PIC16F1454-I/JQ PIC16F1454-I/ML PIC16F1454-I/P PIC16F1454-I/SL PIC16F1454-I/ST PIC16F1454T-E/JQ PIC16F1454T-E/ST PIC16F1454T-I/JQ PIC16F1454T-I/ML PIC16F1454T-I/SL PIC16F1454T-I/ST PIC16LF1454-E/JQ PIC16LF1454-E/ML PIC16LF1454-E/P PIC16LF1454-E/SL PIC16LF1454-E/ST PIC16LF1454-I/JQ PIC16LF1454-I/ML PIC16LF1454-I/P PIC16LF1454-I/SL PIC16LF1454-I/ST PIC16LF1454T-I/JQ PIC16LF1454T-I/ML PIC16LF1454T-I/SL PIC16LF1454T-I/ST
- Microcontrollers > 8-bit Microcontrollers
PIC16F1454E/ML, PIC16F1454 E/ML
