Datasheet Microchip PIC16F1455T-I/JQ — Даташит
Производитель | Microchip |
Серия | PIC16F1455 |
Модель | PIC16F1455T-I/JQ |
![]() 8 предложений от 8 поставщиков Микросхема Микроконтроллер 8, 8Bit Microcontrollers - MCU 14KB Flash 1024B RAM 48MHz Osc, USB 2.0 | |||
PIC16F1455T-I/JQ Microchip | 36 ₽ | ||
PIC16F1455T-I/JQ Microchip | 76 ₽ | ||
PIC16F1455T-I/JQ Microchip | по запросу | ||
Корпус | UQFN |
ADC Input | 5 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 16 MHz, 32 kHz |
Lead Count | 16 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 48 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 3 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Number of USB Modules | 1 |
Package Width | 4x4x0.5mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 14 |
Размер памяти программ | 14 KB |
SPI | 1 |
SRAM | 1024 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: PIC16F1455 (29)
- PIC16F1455-E/JQ PIC16F1455-E/ML PIC16F1455-E/P PIC16F1455-E/SL PIC16F1455-E/ST PIC16F1455-I/JQ PIC16F1455-I/ML PIC16F1455-I/P PIC16F1455-I/SL PIC16F1455-I/ST PIC16F1455T-E/JQ PIC16F1455T-I/JQ PIC16F1455T-I/ML PIC16F1455T-I/SL PIC16F1455T-I/ST PIC16LF1455-E/JQ PIC16LF1455-E/ML PIC16LF1455-E/P PIC16LF1455-E/SL PIC16LF1455-E/ST PIC16LF1455-I/JQ PIC16LF1455-I/ML PIC16LF1455-I/P PIC16LF1455-I/SL PIC16LF1455-I/ST PIC16LF1455T-I/JQ PIC16LF1455T-I/ML PIC16LF1455T-I/SL PIC16LF1455T-I/ST
- Microcontrollers > 8-bit Microcontrollers
PIC16F1455TI/JQ, PIC16F1455T I/JQ
