Datasheet Microchip PIC24FJ64GA702-I/ML — Даташит
| Производитель | Microchip |
| Серия | PIC24FJ64GA702 |
| Модель | PIC24FJ64GA702-I/ML |
16-битный микроконтроллер PIC24F с флэш-памятью ECC объемом до 256 КБ, оперативной памятью 16 КБ и чрезвычайно низким энергопотреблением.
Купить PIC24FJ64GA702-I/ML на РадиоЛоцман.Цены — от 37 до 275 ₽13 предложений от 9 поставщиков IC MCU 16BIT 64KB FLASH 28QFN. PIC PIC® 24F Microcontroller IC 16-Bit 32MHz 64KB (22K x 24) FLASH 28-QFN (6x6). Embedded... | |||
| PIC24FJ64GA702-I/ML Microchip | 101 ₽ | ||
| PIC24FJ64GA702-I/ML Microchip | 105 ₽ | ||
| PIC24FJ64GA702-I/ML Microchip | 125 ₽ | ||
| PIC24FJ64GA702-I/ML Microchip | от 253 ₽ | ||
| Корпус | QFN |
| Количество выводов | 28 |
| # of Comparators | 3 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit PIC MCU |
| CRC/Scan | Yes |
| Cap. Touch Channels | 12 |
| Configurable Logic Cell Modules | 2 CLC |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 8 MHz, 31 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 3 including complementary outputs |
| Max 16 Bit Digital Timers | 3 |
| Max A/D Resolution | 12 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 32 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 2 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 64 Kbytes |
| RAM | 16384 bytes |
| SPIв„ў | 3 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 10 |
| UART | 2 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
PIC24FJ128GA702 PIC24FJ128GA704 PIC24FJ128GA705 PIC24FJ256GA702 PIC24FJ256GA704 PIC24FJ256GA705 PIC24FJ64GA704 PIC24FJ64GA705
Серия: PIC24FJ64GA702 (8)
PIC24FJ64GA702I/ML, PIC24FJ64GA702 I/ML
