Datasheet Microchip PIC32MX150F128DT-50I/PT — Даташит
| Производитель | Microchip |
| Серия | PIC32MX150F128D |
| Модель | PIC32MX150F128DT-50I/PT |
Купить PIC32MX150F128DT-50I/PT на РадиоЛоцман.Цены — от 113 до 387 ₽11 предложений от 11 поставщиков IC MCU 32BIT 128KB FLASH 44TQFP. MIPS32® M4KTM PIC® 32MX Microcontroller IC 32-Bit 50MHz 128KB (128K x 8) FLASH 44-TQFP... | |||
| PIC32MX150F128DT-50I/PT Microchip | 201 ₽ | ||
| PIC32MX150F128DT-50I/PT | 290 ₽ | ||
| PIC32MX150F128DT-50I/PT Microchip | 387 ₽ | ||
| PIC32MX150F128DT-50I/PT Microchip | по запросу | ||
| Корпус | TQFP |
| Количество выводов | 44 |
| # of Comparators | 3 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | 32-bit MIPS MCU |
| CRC/Scan | Yes |
| Cap. Touch Channels | 13 |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 8 MHz, 32 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 5 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 50 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 2.3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 44 |
| Размер памяти программ | 128 Kbytes |
| RAM | 65536 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 105 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 13 |
| UART | 2 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
PIC32MX110F016B PIC32MX110F016C PIC32MX110F016D PIC32MX120F032B PIC32MX120F032C PIC32MX120F032D PIC32MX130F064B PIC32MX130F064C PIC32MX130F064D PIC32MX130F256B PIC32MX130F256D PIC32MX150F128B PIC32MX150F128C PIC32MX170F256B PIC32MX170F256D PIC32MX210F016B PIC32MX210F016C PIC32MX210F016D PIC32MX220F032B PIC32MX220F032C PIC32MX220F032D PIC32MX230F064B PIC32MX230F064C PIC32MX230F064D PIC32MX230F256B PIC32MX230F256D PIC32MX250F128B PIC32MX250F128C PIC32MX250F128D PIC32MX270F256B PIC32MX270F256D
Серия: PIC32MX150F128D (18)
- PIC32MX150F128D-50I/ML PIC32MX150F128D-50I/PT PIC32MX150F128D-50I/TL PIC32MX150F128D-I/ML PIC32MX150F128D-I/PT PIC32MX150F128D-I/TL PIC32MX150F128D-V/ML PIC32MX150F128D-V/PT PIC32MX150F128D-V/TL PIC32MX150F128DT-50I/ML PIC32MX150F128DT-50I/PT PIC32MX150F128DT-50I/TL PIC32MX150F128DT-I/ML PIC32MX150F128DT-I/PT PIC32MX150F128DT-I/TL PIC32MX150F128DT-V/ML PIC32MX150F128DT-V/PT PIC32MX150F128DT-V/TL
PIC32MX150F128DT50I/PT, PIC32MX150F128DT 50I/PT
