Datasheet Microchip PIC32MX250F128BT-50I/ML — Даташит
СерияPIC32MX250F128B
МодельPIC32MX250F128BT-50I/ML
PIC32MX1XX/2XX Family Data Sheet
PDF, 3.4 Мб, Версия: 04-11-2016
IC MCU 32BIT 128KB FLASH 28QFN. MIPS32® M4KTM PIC® 32MX Microcontroller IC 32-Bit 50MHz 128KB (128K x 8) FLASH 28-QFN...
119 ₽
КорпусQFN
Количество выводов28
# of Comparators3
ADCC with ComputationNo
Angular TimerNo
Архитектура32
CPU32-bit MIPS MCU
CRC/ScanYes
Cap. Touch Channels13
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C2
Math AcceleratorNo
Max # PWM outputs5 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution10 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz50
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)2.3
Peripheral Pin SelectYes PPS
Pin count28
Размер памяти программ128 Kbytes
RAM32768 bytes
SPIв„ў2
Temp. Range Max.105
Temp. Range Min.-40
Total # of A/D channels9
UART2
Zero Cross detectNo
PIC32MX110F016B PIC32MX110F016C PIC32MX110F016D PIC32MX120F032B PIC32MX120F032C PIC32MX120F032D PIC32MX130F064B PIC32MX130F064C PIC32MX130F064D PIC32MX130F256B PIC32MX130F256D PIC32MX150F128B PIC32MX150F128C PIC32MX150F128D PIC32MX170F256B PIC32MX170F256D PIC32MX210F016B PIC32MX210F016C PIC32MX210F016D PIC32MX220F032B PIC32MX220F032C PIC32MX220F032D PIC32MX230F064B PIC32MX230F064C PIC32MX230F064D PIC32MX230F256B PIC32MX230F256D PIC32MX250F128C PIC32MX250F128D PIC32MX270F256B PIC32MX270F256D
PIC32MX250F128BT50I/ML, PIC32MX250F128BT 50I/ML
На английском языке: Datasheet Microchip PIC32MX250F128BT-50I/ML
