Datasheet Microchip PIC32MX270F256D-V/ML — Даташит
Производитель | Microchip |
Серия | PIC32MX270F256D |
Модель | PIC32MX270F256D-V/ML |
![]() 25 предложений от 14 поставщиков Микросхема Микроконтроллер 32, 256KB Flash, 64KB RAM, 40MHz, 10Bit ADC, UART, SPI/I2S, I2C, CTMU, USB, 44 QFN 8x8x0.9mm TUBE | |||
PIC32MX270F256D-V/ML Microchip | 146 ₽ | ||
PIC32MX270F256D-V/ML Microchip | от 386 ₽ | ||
PIC32MX270F256D-V/ML Microchip | 495 ₽ | ||
PIC32MX270F256D-V/ML Microchip | по запросу |
Корпус | QFN |
Количество выводов | 44 |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Cap. Touch Channels | 13 |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Math Accelerator | No |
Max # PWM outputs | 5 including complementary outputs |
Max A/D Resolution | 10 bits |
Max. CPU Speed MHz | 50 |
Number of USB Modules | 1 |
Рабочий диапазон температур | от -40 до +105 °C |
Operation Voltage Min.(V) | 2.3 |
Pin count | 44 |
Размер памяти программ | 256 Kbytes |
RAM | 65536 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 105 |
Temp. Range Min. | -40 |
Total # of A/D channels | 13 |
UART | 2 |
Zero Cross detect | No |
PIC32MX110F016B PIC32MX110F016C PIC32MX110F016D PIC32MX120F032B PIC32MX120F032C PIC32MX120F032D PIC32MX130F064B PIC32MX130F064C PIC32MX130F064D PIC32MX130F256B PIC32MX130F256D PIC32MX150F128B PIC32MX150F128C PIC32MX150F128D PIC32MX170F256B PIC32MX170F256D PIC32MX210F016B PIC32MX210F016C PIC32MX210F016D PIC32MX220F032B PIC32MX220F032C PIC32MX220F032D PIC32MX230F064B PIC32MX230F064C PIC32MX230F064D PIC32MX230F256B PIC32MX230F256D PIC32MX250F128B PIC32MX250F128C PIC32MX250F128D PIC32MX270F256B
Серия: PIC32MX270F256D (18)
- PIC32MX270F256D-50I/ML PIC32MX270F256D-50I/PT PIC32MX270F256D-50I/TL PIC32MX270F256D-I/ML PIC32MX270F256D-I/PT PIC32MX270F256D-I/TL PIC32MX270F256D-V/ML PIC32MX270F256D-V/PT PIC32MX270F256D-V/TL PIC32MX270F256DT-50I/ML PIC32MX270F256DT-50I/PT PIC32MX270F256DT-50I/TL PIC32MX270F256DT-I/ML PIC32MX270F256DT-I/PT PIC32MX270F256DT-I/TL PIC32MX270F256DT-V/ML PIC32MX270F256DT-V/PT PIC32MX270F256DT-V/TL
PIC32MX270F256DV/ML, PIC32MX270F256D V/ML
